hey guys, So I had my first somewhat... Ok season with my apex as the sled it can be. upgraded the track and did the clutching right... Only thing I'm missing on my clutching is the rollers. But I'm still having some good ol turbo lag, getting into boost and the on off throttle can be a bit slow coming back in. when boost starts to climb it hits hard and usually bounces off the rev limiter once or twice until clutches catch up. I'm thinking its due to the stock rollers which I have yet to replace. I also have a CR racing intake.
on off the throttle theres some but once your up and away its alright. My exhaust should not any any leaks really. I had it all apart when I did my track and I welded all and any cracks in my SS y pipes. I put copper donuts in and all them goodies
I don't have a boost leak as far as I can tell either. it responds to my boost T when adjusting in fine amounts and reaches peak boost quickly and sustains it. I did have a couple over boost times last winter. Climbed a hill and it was bouncing off the rev limiter, did a second run and seen it wanted to climb to 20# or more... Its a 290 hp pump gas kit so I know boost should be 15-16# depending.
I ride with a guy whos got the newer MCX kit on his 07 or 08 MCX apex which responds much quicker. and one thing I notice in the newer kits Is they have a much better BOV and it also gives off some Flutter even under very light throttle and letting off which I know could be turbo surge and/or it holding some positive air pressure in the charge tubes.
Now I have 2 Bov's. the plastic one under the headlights and one on the side of the I/c. I was thinking maybe I could increase my responsiveness would be changing out the plastic BOV? I've heard lots of people say they freeze up and have a lot of issues with them?. I'm thinking if i go to a billet style one and get it to hold in a WEE bit of pressure, ~1 psi? so I'll get a little flutter maybe that's all I need to reduce my lag. So It wont completely dump pressure on and off the throttle it will hold a little so when I open up the throttle in the trees It'll be more "ready to go" vs having to start from scratch almost in vacuum to positive pressure for the brief moment?
also the I/c BOV, Do people keep those? are they in the newer MCX kits? having a dual BOV design?
I know that if you have positive pressure or too much it could cause the sled to continue to run on when the throttle blades are closed as its forcing air by them still and fueling for it.
thanks for any ideas or recommendations on it all! look forward to hearing opinions on it all
