boost lines on silber billet block?
M
MacDawg productions
532
106
Van Isle, British Columbia
Hey where did you guys plumb your boost lines or line into the billet throttle block on your silber kit? I'm assuming that is the best location for them. possibly where the small allen bolt goes in on the side? Did you use a brass threaded fitting with the barb end for a secure fit??
kanedog
Undefeated mountain clutching champ of the world.
3,112
3,869
I don't have a silber but here's what I did for my boost lines.
After the throttle bodies one line goes to the blow off valve.
I drilled 3 brass fittings on the air box where they are accessible for maintenance and visual checking. They are for fuel controller, boost guage, turbo. I did plumb in an inline manual boost controller and mounted to the frame where it is accessible.
I could have went with just one fitting and tee'd the rest but I didn't like the idea of brittle plastic tees dangling everywhere.
I used blue loctite on the threads and small zip ties on the brass fitting for piece of mind and longevity.
