I'm running on older silber kit. (box boost housing, oil pump.) before the ECU flash. (Dobeck AFR) Iv ridden a few other turbos and noticed that my waste gate (internal) and blow off are vary, vary quiet. I'm only running at 5lbs. and I can barely hear anything, even the turbo. It seems to be running grate. No det codes or anything. I'm also noticed that my boost gauge doesn't seem to hold a steady reading. it seems to bounce from 1-5bs. Iv T-d off the blow off valve for the boost gauge. and I'm tied into my secondary injector plate for vacuum/boost. (Both sides, PTO/MAG) and t-d from there to my blow off and boost gauge. could I be causing 'LEAK." or is all this normal. or leak some were else.
PS the exhaust on this is crazy loud. could It just be covering up the sound?
Another dumb question. Do I need a blow off? I know Boondocker's kit doesn't use one.
