I have a 09 M8 153" Sno Pro. I have a SLP single pipe installed on the sled.
In the secondary I have the stock orange secondary spring installed with a shift assist washer and a Black Diamond 42/36 helix.
The primary is now a SLP Black/pink 120/340 with 73 gram Arctic Cat weights (for now). I ride from 4-7,000 feet and weight 170.
The backshift isn't bad but, it isn't stellar either. Is there a slightly stronger secondary spring anyone would recommend that may help a bit with the backshift?
I don't understand how to read the secondary spring specifications either. I am used to Yamaha secondary numbers. Do the Arctic Cat secondary spring numbers read like the primary springs since they aren't used in a torsional application?
Thanks for any help you can provide
Any help on the subject would be appreciated. A spring chart with numbers for comparison would be even better.
Thanks
Thanks
