Hey Moto
Thanks for the info. you obviously know more about the fuel curve on the Nytro then most from the development of your fuel bridge. I am curious do all nytro's run rich at just certain elevations or is it more across the board and they are just set up to run rich. I find this interesting because from what i read when doing research before buying an exhaust system, some people were reporting that they developed a lean pop after installing a slip or full exhaust system. this of course led me to beleive that the sleds were running lean and certain points. The other thing i found interesting was you can only bump of the fuel on the idle circuit through the speedo. Al lot of people were saying that you were able to set it across the full range. I realize some things you read on the internet forums are not true but there seemed to be a general consensus on this two things up until now. Again thank you for clearing thngs up a little
#1 - The internet is gospel.
#2 - The Nytro fuel system uses an IAT, ECT, and MAP sensors alone for fueling adjustment data
i.e. - air temp, coolant temp, pressure sensors - archaic technology at best.
#3 - Our findings were that the "lean pop" were either a TORS switch set out of range, throttle body sync issues, or the simple fact that all of the sleds we tested also had a "lean pop" with the OEM exhaust... The huge suitcase muffler just does a fine job of masking it.
#4 - Our belief is the pop is due to an over-enriched mixture in the exhaust system. Upon throttle regression (letting off throttle), the mixture ignites in the super heated exhaust... a simple backfire.
#5 - As far as the CO's (setting in the speedo)... We ran an o2 sensor and DynoJet setup on an OEM sled (with aftermarket can) for an entire season while doing R&D for the Bridge - CO's are a waste of time unless you need to clean up your idle. There
are minimal and periodic lean spots in the Nytro, but none of them are of a detrimental magnitude on a NA sled.
#6 - The internet is gospel....
