T
Does anyone know where to get Av-gas, 100LL around Great Falls, Mt area?
I Run it in my big bore stroker Banshee (quad) 420cc twin that turns 10,500rpm's. (two stroke) Never had a problem other than the aditive they put in it that separates the water. Makes little pink balls of goo that plugs fuel filterssorry to be a dic k but the fuel is designed to use at below 4500 rpm and at high alt
you can get fuel designed for your sled 2 stk high rpm from fuel companies .
ever run a AFR on it and see what yer wastin ? I did on my warrior a good plug reading was runnin 10.2 on my AFR .I Run it in my big bore stroker Banshee (quad) 420cc twin that turns 10,500rpm's. (two stroke) Never had a problem other than the aditive they put in it that separates the water. Makes little pink balls of goo that plugs fuel filters
To be honest with you I don't even know what AFR is. I never trusted an octane booster because of the oil mix. I believe there is a lot of a acetone in octane booster that doesn't mix well with synthetic oils.ever run a AFR on it and see what yer wastin ? I did on my warrior a good plug reading was runnin 10.2 on my AFR .
I really don't want to come off as an azz. :face-icon-small-ton What is av gas? As far as I know it's 100 octane low lead with some altitude additivesair fuel ratio, good reading on a 4 stroke is 14.7 to 1, 17.0 is lean 10.0 will normally flood a 2 stroke . av gas wont hurt but it burns wrong for your quad 2stk to slow
thats all, I mix in my quad so it doesn't rattle .
