magic numbers still 3 turns in right???
and try to avoid sustained runs at 5,800-6,200 RPM
When I stated max oil pump output I should have said "Way more oil than would normally be put out by the pump when the cable is connected correctly". So with the increase in oil into the fuel /air mix the amount of fuel is decreased and replaced by oil. Oil doesn't burn at the same rate as fuel so with less fuel to cool the combustion cycle the mixture burn temperature increases causing a "Lean" condition which causes high EGT. There's only so much oil, fuel and air ingested each cycle. If we change the ratio's then we affect the lubrication, burn rate and temperature of the cycle. That's a long winded explanation....as I see it. I am sure there are some engineers on her that could explain it much better.
I would like to see real world EGT data to support your claim of high EGT due to a lean condition caused by adding oil to the gas. Unless you have data you are just guessing that is what happens.
No, it's even more bizarre than that. He's claiming high EGT temps when the oil pump started pumping extra oil. He's claiming the oil pump adding excessive oil displaces fuel coming through the carbs and creates a lean Air Fuel mixture.
Ring-ding-ding-ding-dingeringeding.....
I bet some of the people on this forum are very hard to work with. They think they know it all. But don't know crap. These are the same people that will bash on miss spelling, because it makes them feel better that they are right about something.
This subject has been beat to death with worng or worthless posts.
Add oil if you want, turn your oil pump up if you want, F-ing turn your oil pump down if you want. It's your $10000 snowmobile, be a big boy and make up your mind.
Did I spell anything wrong. I hope not.
What does the fox say? POW POW POW POW POW!
You sir have added nothing to this discussion. I started this thread to make an attempt at bringing some science to the discussion with the result to be the ability to make an informed decision as to whether or not adding oil to the gas helps or hurts. If you are a “big boy” and just make decisions on critical functions in a 2 stroke motor, by the seat of you britches, then fine, but don’t berate those who want to understand what works and what is forum myth. I was hoping to remove this issue from, .. “well I hear a lot of guys do it, so I do it”. There has been a lot of good information presented in this thread, and some speculation, so hopefully more useful data/info will continue.
You should have put a ? at the end of the sentence, LOL!!!!!!!!!
i ride with poo peoples.thats why i carry a tow rope.LOL
Google search info:
No Extra Oil for Posi-Lubrication Systems
Under no circumstances should pre-mix oil be added to the fuel tank of a positive lubrication system 2-stroke. For the reasons stated above, adding oil in this way will make the engine run hotter (leaner), which can lead to seizures.
