R
ral494
New member
I found an old mxz with the 670HO motor and am just going through it
Ive cleaned and went through the secondary installed new cam buttons
Running the stock Helix and beige spring set on B6
Ive pulled the primary off and noticed there were no o rings in behind buttons
everything else seems ok but the arms have a bit of movement not side to side on the pin... but when you torque the arm side to side???
The thing rattles like crazy
How much move,ment is normal
The rollers seem fine
297 ramps look ok
The splines look ok
I have not removed the cup yet
What are the specs for the bushings?
The are 3 washer weights in each arm how much does each weigh?
I have no book and just trying to figure out how much this has been messed with
Any help is appreciated
297 ramps look ok
The splines look ok
