Sent you a PM
Couple other things i would check, along with the TPS. Not in any certain order, but possible problems.
1. Clutch alignment. I always check this, as well as set float on secondary.
2. Shift-out. Are your clutches fully shifting? Use a marker and draw a line from the center to the outside radius of clutches. The belt will rub away the marker, showing how far it is shifting. Primary rubs from center out, secondary from outside to center.
3. Belt to sheath clearance! Notoriously out of spec from factory, often requiring machining to get correct, even to get close really. Loose will result in lower belt pressures, and less shift.
4. Spring problems. Check them and condition of both clutches. Some primary springs bind up on the clutch spider or jam nut. Look for rub marks on outside edge of spring.
5. Do clutches both function/move smoothly with springs removed? Primary especially. Some clutches are really tight in the bushings. They may "break in" and loosen up, or keep sticking.
6. Belt deflection set right?
7. Belt itself. See any problems with it?
8. Drive train. Everything spin smooth/freely?
Looks like alot, and does require some tools for checking all that, but all very possible RPM robbing issues. Some of them common.
