2017 mtn cat 153 21/49?
M
madsledder
Hey all. I am curious if it is worth doing the higher gears on my 17 mtn cat 153 3". Y-pipe and can, and doing mds weights for this season. Ride 3-8000' trees, climbing all around mtn sled. Would go from 19/50 to 20/49. Any advice would be great. Thanks in advance.
I prefer the 2.45 to 2.50 gear range makes the sled a bit more lively. a lot smoother on take off with more pull in the mid to upper and you can re use the stock chain and just change gears.
MDS weights are going to have it upshifting harder already no? I wouldn't.
So does the 20/49 fit with the stock chain? Where’s the best place to purchase these gears from? Thanks
I would double check with your dealer to make sure they will fit but the
20t is 2602-824 and the 49 t is 2602-875
yes the 20 -49 fits the stock chain i just did mine and like it so far .but all ive done is a trail ride not enough snow to go off trail
