4
Hi, I'm looking for some help on my 2014 pro 800. Last season it ran perfectly until the last ride of the season. Before that ride I added the following upgrades: SLP single pipe & can, PCV Fuel Injection Module& & Clutching. The last ride was also a late spring ride with temps in the 60's.
I noticed my sled smoked a lot more than usual when I got it back from the shop after adding the pipe & can & PCV. It also left a lot of oil residue below the can and in the belly pan.
During the ride it bogged really easily on the trail until I could open it up and burn off the excess oil, then it seemed to run fine once it was past 3/4 throttle. It had little power at 1/2 throttle and cut out a couple times leaving me in a bad situation.
Does the PCV adjust the oil injection pump? Could this just be a combination of temperature and the wrong map installed?
Any help is appreciated. Thanks.
