I have a new to me 2010 Twisted Turbo M8 with a 2013 BD 3D turbo box. (The previous owner replaced the original attitude fuel controller)
If I do a wide open pull, the afr stays right around 11.8 for two seconds, then it swings lean to the point where it doesn't even read numbers on the afr. It does this on any boost level and with any fuel controller numbers.
You can watch the little leds on the afr swing from around 12, then shoot all the way lean.
The sled still pulls and runs awesome even when it reads lean (I didn't dare hold it for more than 1 second after going lean) with no popping, no Det light, no signs of running poorly (running straight 100ll avgas)
I upped my fuel numbers to 100 at higher rpm to see if I could bring it down and it had no effect.
I have two hypothesis...
One is that it is actually running rich enough for incomplete combustion and the wideband registers the extra o2 as being lean.
The second more likely one is that the fuel controller either isn't pushing the secondary injectors or doesn't have enough power. I found some old posts talking about power issues with the 2013 BD boxes.
Anyone ever seen anything similar?
