2012-2016 Arctic Cat 800 SLP Single Pipe Set $400
offroadmatt
7,326
470
83
Sweetwater, CO
Single Pipe set off a 2013 Proclimb 800. Pipe had a additional O2 Sensor Bung welded in before being Ceramic Coate. Currently has a removable plug installed in it can be used for use with autotune or a wideband. And the Y-Pipe has been drilled for EGT gauges. Will need new Seals which can be ordered through SLP. Also levaing the muff pot on it. Worth the $400 alone....
From SLP website:
This impressive single pipe from SLP is sure to make your buddies green with envy. It delivers an additional 8.5 horsepower peak and sheds a staggering 20.8 pounds of weight. What this means in the field is 3 to 3 1/2 sled lengths quicker in a drag race and 2-3 mph faster top end speed. Throttle response is substantially better than stock with much stronger pull, especially noticeable in the low to mid speed ranges. The reduction in weight is very evident, making this sled noticeably easier to handle and control, especially in those tight, technical spots we all love so much. This single pipe kit includes y-pipe, pipe and silencer all of which are ceramic coated.
ERA 2014 Silencing Technology
SLP tested and passed SAE J-2567 stationary sound test below 88 decibels.
A Power Commander V fuel control box and some clutching changes are require.
IMG_2229 [363688].jpg IMG_2234 [363698].jpg IMG_2233 [363696].jpg IMG_2232 [363694].jpg IMG_2230 [363690].jpg IMG_2231 [363692].jpg IMG_2247 [363700].jpg
kiliki
13,214
2,400
Nampa, Idaho
so is this pipe for a stage 3?
as it is different from the stage 2 pipe. if so it will only work on the stage 3 motor with the slp jugs and head.
offroadmatt
7,326
470
83
Sweetwater, CO
This is just their standard Pipe set. To my knowledge they don't have different levels of pipe sets. They just use this pipe set with the different stages. As in stage 2 might just be the can and not the full set.
offroadmatt
7,326
470
83
Sweetwater, CO
Why is this still sitting in my garage? If your even thinking about buying a SLP exhaust system for you Proclimb, look no further. This is a smoking deal on a nice used setup.
