Holtz stopped selling them when they stopped selling Cat parts. They were semi-fairly priced. The only shop I know beyond Holtz is AMP. Look at part number: AMP-3136
http://www.aftermarketproducts.com/catalog.php?mach_type=S
I've run a 2005 M7 since 2005, so I'm familiar with them. Other suggestions:
Motor Mounts: They have likely already gone out and been replaced and perhaps a couple times. Keep an eye on these throughout the season. When cracking, replace with 2006 mounts - they are harder durometer rubber.
Look at the exhaust side motor mount and insure that it has the 2006 heat shield over it. The exhaust heat on the M7 will damage the mount without that shield on it.
A-Arms: Keep an eye on the front end bushings. Again, with that many miles they have probably been replaced already. If you want good ones, PM bparks on here - the best ones made.
Steering post: Probably one of the most important mods is to replace the stock post. I've broken and watched others break this post a number of times. Scary stuff when smashing down the road. M7's are the worst. PM Wildchild on here for a bad to the bone post that won't break or bend. He can make it whatever height you want, so you can avoid a riser if you want the cheap route. Look at backcountryislife posts on his set-up... best to do it that way if you can afford a new post and pivot risers. Whatever you do, replace the post though.
When replacing the post, its a good idea to drop in a BDX support bearing. I also run the ratsled steering hoop support. Ratsled support, BDX bearing and wildchild post are the ticket to zero steering problems on your sled.
GeoMod: check this out - free mod for rear skid. Makes a difference too!
Revalve shocks - they are weak in the back, revalve now or deal with cracked skid rails.
You are due for new pistons, as others have said. Clean your injectors and powervalves this summer too.
Add extra hood straps! If you wreck and blow your hood off the M7 you will be in trouble (sled won't start). Strap that thing on and avoid that.
Keep your Diamond Drive healthy. One of the seals is installed the wrong direction from the factory. Yours may be fixed. I replaced seals annually on mine to avoid problems. DD service should be the first thing you do after your season is over. Don't wait until fall, water will rust things. I did bearings every 1000 miles. $60 was cheap insurance in my opinion. I put 8-9,000 miles on one of my DD doing bearings every 1000 miles and seals every season.
Vents are important, as others have said. I recommend Mountain Fit, but lots of great options.
That's all I can remember right now. Feel free to PM me if you have questions. You got a great deal, but drop another $400-$500 and make it reliable. I have some M7 parts for sale that could help keep you on the cheaper side, see below. Enjoy, they're great rigs!
http://www.snowestonline.com/forum/showthread.php?t=314653
http://www.snowestonline.com/forum/showthread.php?t=314654
http://www.snowestonline.com/forum/showthread.php?t=314171
Brett
