R
selling 2005 switchback 144 has the slp performance package on it porting, Head ,pipe, can,slp air box. just had the crank true and welded,newer top end stock 06 pistons,500 miles ago. rails powder coated black,torque arms and A arms red rear bumper red.has the 225lb spring on the front track shock.Has the new torsion springs 7042079-067 Spring, Torsion, LH, STD [.375/47 °]
7042080-067 Spring, Torsion, RH, STD [.375/47 °]
.Clicker shock in the rear.HRP spindles.had the seat done in all black.extra new belt newer clutch that was balanced by Indy Dan. all new bearing on jack shaft and Idles wheels and new bushings in the skis .has tower shock vents, side panel vents.and other vents .has extra coolers under the tunnel and running boards. has the skins knee pads and skins had guards.frog skins on all vents.RMK Cover $2,500 OBO now the bad has 9xxxx miles on it.gas gauge works but does not show right.and a crack fender, that's been fixed.small dent in the lower A-arm. very fast sled. with lots of power.
