2001 polaris gen 2 chassis with a 97 non ves 700 motor. It has rk tek turbo cut head, tm40 rack style carbs, powerjets, stock pipe with turbo flange welded on it, 16G turbo, pull and push engine brace, fresh spi coated pistons and big bearing crank with aftermarket connecting rods with no more than 20hrs on them, never been burned down or blew up, 100lbs compression with turbo head, 140 with slp powerdome, slp secondary clutch, slp mtx weights, brad story oil pump, premixed fuel with 40:1 blue marble, rsi bars and 6" riser, fuel, boost, turbo oil pressure, and racepak gauges, psi throttle block, custom radius arms and steering rods, lightweight trailing arms, walker Evan shocks with fox float valves, Simmons skis, lightweight fuel tank, boss seat(small tear that's been fixed) gas can holder, ekholm powdercoated tunnel, 156" track, extrovert drivers, dropped and rolled chaincase, "big boy" torsion springs on rear suspension, mesh hood and also a fiberglass hood, comes with kehein carbs, slp pipes and heads, and stock air box as well. I know I'm forgetting some but that's most of it. Call or text (208)390-2928. $2000
Thank you.
Thank you.
