174 Sidewinder build and season ride report.
Turblue
1,022
406
Alberta
Thanks I’m pretty happy how it turned out. Wanted to stay stock looking with a twist. I was really hoping someone would have came out with a lower profile seat. I know skinz has one but wasn’t a fan. Also trying the Munster finger throttle this year....should be here soon.
Calvin42
1,375
833
Cantonment, FL
Love the fact that you kept it clean looking. That right there is what a factory sled should look like and be. Not over done, just the right amount of graphic's. Hoping the Yamaha guys are watching your post. Not currently a Yami guy, but definitely on the fence. I did own a Nytro with an MCX 240 kit and absolutely loved the power. Not a big fan of the chassis, but in it's day, wasn't to terrible. I've never been brand loyal as I ride what "I" believe the best sled is currently on the market that works for my riding style. Once the big four start giving me incentives to keep coming back to them, then I'll start thinking about it. Have been following the Sidewinder posts very closely as I like to have the most info before I make a big purchase. I think I've watched all the youtube videos I could find and read all the reviews I could find and seems as though the Sidewinder is the real deal. I accept the fact it carry's some extra weight, it's just reality right now. There's just no denying how a fourstroke can put a smile on your face. Keep us posted on the ride reviews.
kakwa climber
70
Have you rode it yet? I’m patiently waiting for your review lol
2XM3
3,280
1,370
Bitteroot valley,MT
Nice job !! The only reson I have not went back to a yammi is the lack of a factory 174-3" ,or bigger track its insane they don't do one from the factory
Turblue
1,022
406
Alberta
Had a great family day ride on the weekend ...sidewinder worked great. The ride was pretty tame but did manage to find some good snow in the trees to try it out a bit. The trail in was freshly groomed so didn’t really get to see how the Elka shocks perform. Had a issue with the snowflap wanting to ride on top of the track...need to figure out a support ...since the stock rear bumper supported. Also had a issue with the skidoo adjustable riser...seemed like it wanted to move in and out a bit..had the the screw pretty tight so not sure. Munster finger throttle worked great. Anyway hopefully next weekend get some good video time.
Turblue
1,022
406
Alberta
Just wanted to post a quick update after a good 4 days of solid riding in 2-3’ of good snow. We rode a few different locations in British Columbia, in various levels fresh snow and temperatures. Just so we are all clear this sled is basically all stock, besides the 174 and cr resonator pipe…….It was my choice to do the 174 and cosmetic items to make it my own, and never really needed it to "make it work". Suspension geometry, clutching, and gearing is all stock. Im 6’5” & 235 plus gear and cargo so the the extra floatation with the 174 works well for me
Sled Specs
2017 Yamaha sidewinder
Cr racing resonator pipe
174 x 15 x 3” camoplast 9271
Stock clutching and gearing
8JP stock belt
Elka ski shocks STG 3
Fox Float 3 rear , and stock coil rear skid front shock
Handling
Front ski shocks – Elka STG 3 preload 10mm and compression clicker 14
Rear skid rear – Fox Float 3 set @ 150psi
Rear skid Front – 2/3 preload on that shock.( haven’t touched from factory setup)
Limiter straps – stock location
So I elected to try some Elka Stage 3 ski shocks…The reason i went this route is I wanted to try a set of coil over shocks vs the float 3 shocks. These shocks do perform well...ride quality is premium through the rough trails to the riding areas. I have noticed that the sled wants to ski dive more than the floats in the corners. I need to play with the compression clickers more and I'm confident it will help.
Deep snow handling they never felt like they were sluggish compared to the fox float but a true test would be to swap back. So more work to do there.
As for climbing capability..... im not looking for my sled to climb a wall…I just want it controllable when doing a technical climb, need to get into the power and still have control. I did manage to find some fairly steep and deep hills…sled seem to hold the ski just off the snow at a manageable level. I never felt like it was wheeling out of control. I believe the 174 does help with this. I have ordered a Fox QS3 rear shock to try it with the lock out feature...more to come on that...
As for tree riding it performed great…very responsible to your body position. I know with the previous 4stroke sled i felt it was hit or miss how it was going to turn out. The Sidewinder is very predictable on how it will react to technical situations in the trees. I truly have gauged the handling of the sled by how tired i am at the end of the day, my Apex I was wiped, Sidewinder I felt no different than my XM 174 T3.
Clutching and belt heat
We put on around 60-70 miles each day…I burned a full tank and almost a 3.3gal jug of spare fuel…So needless to say the throttle was to the bars most of the day. I did stop once in a while to check clutch heat and signs the belt is wearing prematurely. Clutches were warm but not 850 warm…lol I only commented that because my 2 riding buddies blew a few belts in that 4 days….. As for backshifting and rpm it seemed to be spot on.... when I could see the gauge.
Power & air Intake
Power was very smooth and responsive….One of the Guys that tried it said he was surprised how responsive it was. We also got into a spot where it was technical through a ravine, through some trees and a straight shot to the top. For as deep as the snow was I was amazed how it pulled all the way to the top. The riding style with these sleds is completely different that the 2 strokes so keep that in mind when you try one.
I never did install an external air intake as I wanted to see how it preformed without, I figured spending this kind of coin you really shouldn’t have to change anything to make it perform. The results of having the sled covered in snow all week….never felt once it was bogging or hindering the performance in anyway. I rarely stopped to clear the snow.
Rolling over
Yes I did manage to bury this beast a few time in the trees…lol. Most of the time I was by myself to get it out and with a few tricks it really wasn’t that difficult. If the slope was right I would just roll it over back on the skis and drive away…Sometimes I needed to shovel a bit to get the sled to go over, but for the most part just rolled on its own. I even flipped it over backwards once and it layed on the hood for 10 mins or so until I could get it uprighted. I did have a bit of oil residue in the air filter....It was a bit oily from new and should of been dry...will monitor this. One issue I noticed was when the sled was around 1/3-1/4 tank and facing downhill after a roll over it wont start until I leveled it….Not sure how the fuel pickups are situated but have contacted the local dealer to investigate more.
Push button start and Munster Controls
Man that push button start worked flawless….Since the key was continuously buried in the snow the button was super handy. Munster finger throttle…well really liking that unit. At first it was a bit awkward cause your looking for the thumb throttle, but by the 2nd day it was a natural thing. Works so awesome in the trees…easy to finesse the throttle while maintain full grip on the bars.
Changes
I had snowflap issue, but the was because of my custom bumper…doesnt have support for it. I ended up removing it and never had heating issues. The Yamaha tether was a issue also….It kept freezing up on me and wouldn’t shut the motor down…which is a scary thing if your upside down. I am going to take it apart and see if dieliectric grease can help. My skidoo handlebar bag(short one) kept knocking my tether off, so I eneded up reversing it around. Munster reverse button, had a wire pull out of their factory clip…not sure if something really tugged on the wire or their factory crimp wasn’t any good..planning on soldiering it.
So that’s the initial impression and ride report….very impressed with the sled and has been a blast to ride....more to come through the season. Like my buddy Jamie says "Power, Performance & Predictable"
Hopefully this helps and any questions let me know.
(Let me know if pics don’t show)
roughrider99
1,805
252
33
Fernie,BC
I had a similar issue with starting on my viper, especially steep downhills with sled on side, if I stopped it would die and have to sit level to start
Turblue
1,022
406
Alberta
Just a update where things are at with the sled.
I got the fox float QS3 and going to give it a try. Right away noticed it’s longer by almost an inch. Compared the rear suspension part numbers from 17-18 and only number I can see different is the control rod. So I got the measurements of both..the 18 is 16.750” and the 17 is 14.250. The longer one rotates the lower mount bracket for the added shock length.
Turblue
1,022
406
Alberta
I do see I have a few issues ....said I was going to be honest on this post...
During the last ride was it was popping out of gear, I cycled the reverse actuator and seemed to cure it. I pulled the chaincase cover off and on 6 rides seems to be quite dirty. Magnet had a fair amount of sludge on it...I assume it’s breaking in and will monitor.
The motor oil tank looks like it’s sweating around where it seals on the chaincase...guessing it will need to be resealed. So make sure you guys check yours. I pulled the rov and seems to be fine and free.
One of the ski rubbers popped out...weird on why that happened.
When around a 1/3 of a tank and facing downward on a steep angle the gas tank pickups don’t want to find the gas. Need to get it leveled or roll it side to side to get it going. I believe the left side worked. So found out this is a issue with them and working on a solution possibly.
yamaha tether needs to go...at the right temp it keeps freezing..going to try Pro Armor
***air filter update*** The next few rides there was next to no oil in the air filter. Also rolled it over 3-4 times getting unstuck.
Otherwise it’s been good, have around 650km on it now.
C37CED90-0708-4ECE-8205-CA32E7C52A5F.jpg 3EBCB2D5-9045-4DB5-A3A0-61508393408F.jpg 8D968302-7BEC-4F44-A718-AC27300787BE.jpg D659D09F-BCB4-41D0-8F0C-5BEBACD87B0B.jpg
