14 Pro dies
Cat man doo
189
46
Dealer told my buddy his coil is bad. What should the resistance be ?
Cat man doo
189
46
This is his words. Any ideas guys ?
Ok, so here's the story on mine! "2013 Pro with Boondocker Turbo, Boondocker box, when new plugs put in, the sled fires up and idles good, then idle slows down and picks up again, then when warmed up it will rip for about 200m then quits like you hit the the kill switch, also won't start after and plugs were somewhat wet. Happens each time with new set of plugs the same.
06redrevx
550
242
Does he have a tether? Mine was doing the same thing one day and I was really frustrated and realized I had a bad tether connection.
I put a small sheet metal screw under the tether cap so the contact point is stronger. Never had a problem since
Cat man doo
189
46
He has a Pingle. Dealer fixed that and he got sled back and was doing the same
Sent from my iPhone using Tapatalk 2
Stroker Customs
488
94
CO
Try disconnecting the Boondocker Box and see if it will idle in stock configuration. Not sure if he is aware that they had a hard start update for the Boondocker box.
