08 XP with hyperlite
D
Nov 30, 2007
8
62
Anyone got any recommendations for clutching in primary for a 2008 XP 154 with the race shaft and hyperlite secondary? Helix? Primary/secondary springs, weights in primary?
Cheers
Ace Freely
2,981
1,147
Wenatchee, WA
I would call Al at the Sled Shed. He probably has more seat time with the hyperlite than most, and knows how to make it work.
Ace
250.814.0018
D
Nov 30, 2007
8
62
I will call around..... There will be 3 of us this year starting out on identical sleds.... All 3 are 154 XP-X's.....One will be completely stock, the other with a shaft and Doo roller, and mine with the shaft and hyperlite. The 2 sleds with the raceshafts will also have secondary's that float. Time will tell.....
Nov 30, 2007
284
3
18
Colorado
PEM 14 with a Cutler red/white spring.
PEM HELIX NUMBERS
-can get at Dalton Industries,
order Cat helix’s
PEM 1 - 53/51
PEM 2 - 53/49
PEM 3 - 48/40
PEM 4 - 49/47
PEM 5 - 49/45
PEM 6 - 47/45
PEM 7 - 47 STRAIGHT
PEM 8 - 45 STRAIGHT
PEM 9 - 51/49
PEM 10 - 46/40
PEM 11 - 50/42
PEM 12 - 60/40
PEM 13 - 60/44
PEM 14 - 52/44
PEM 15 - 57/50
PEM 16 - 55/49
PEM 17 - 53/47 for ported machines
PEM 18 - 51/45
PEM 19 - 62/44
PEM 20 - 60/46
PEM 21 - 58/44
PEM 22 - 58/46
PEM 23 - 48/44
These are TurboAl setups on prior year sleds
.. Mtn proven...
52-44.(PEM 14)...red/white Cutler in hole8.stock primary clicker 3..works awesome to 10000'
53-47.(PEM 17)...red/white in hole8, stock primary but purple/purple spring, clicker4.awesome to 12000'.as high as I've been. It has been dialed in from day1 with a little help from TurboAl..2100miles with no probs... up shift / back shift is insane, accelerates all day if you can keep the throttle pinned.& your clutches run a lot cooler. RER has not failed!! Also have a 3rd setup dialed in with AL’s new primary kit setup...have to call him for details. Al also suggested a 48/42 helix (09/13/05) Stock primary spring in 05 800 = violet yellow 160/230
Ok...u want a 53/47 (PEM 17) or a 52/44 (PEM 14) for a summit...gear to a 19/46 or 19/47 (if u really hill climb), a purple/purple (160/320) (part # 414817900) to your primary & add a Cutler red/white to your Hyperlite. I'll say start around hole 6 for your pretension..
if it 'over revs' at the start lighten it, if the rpms fade on top end tighten it. #1 being tightest-#10 loosest. I find in powder or hard pack u can run the pretension real soft where as in the spring in the real wet n heavy snow we would run it tight...start with this, may need to play with pin weight?
High Voltage
2,533
3,199
Helena, MT
Hasn't your cluches cracked yet ,I seen Turbo Al had a shelf full of them . I had one that cracked by the tower top also take a good look for the fine hair line cracks.
D
Nov 27, 2007
5
Spare parts
Im looking for some hyperlite parts anybody have any for sale? I need the steel adjusting ring in the billet cover. Also need the reverse keys that engage the billet cover when RER is in use. They bolt on with the helix.
I if anybody has anything let me know thanks
Jan 6, 2002
297
10
18
i have a whole clutch in storage! used for 1 season on my 04 rev! it has the reverse and belt deflection adjuster! cant remember the helix number.
i wouldnt part it..but sell it for the right price!
Jan 6, 2002
297
10
18
i'd sell it for 350! the helix is pem18. i took this pic today!
