G
05 Ski Doo Summit RT 1000 Highmark X 162 $4500
05 Summit 1000 SDI with 162In. track. Has many mods to try and lighten it up and help it run great. Has 24XX miles. I purchased this sled almost a year ago and don't know a lot of this history other than thing's I have fixed. Sled has been clutched I have another helix for the secondary but it requires switching to a roller style secondary and the sled currently has a button secondary. Sled comes with extra parts body panel's, hood, a set of Simmon's Flexi ski's, Extra graphic's for hood, belt and a bunch of other stuff. Sled has 140PSI Compression both cylinders can do compression test to verify. Sled has been ridden and has had some tree contact but is straight as a string Nun (front suspension mounting) is straight. Death in family promotes sale I don't want to sell but something has to go.Sled is located in Northern Colorado. Asking $4500 pretty much bottom dollar. might work a little bit need to get it gone though.
Mods:
DynoPort Pipe
DynoPort Trail Silencer
Ceramic coated Y-pipe
Ski Doo Pilot 6.9 Mountain Ski's
Ski Doo XP Thermostat which allows the sled to maintain proper operating temperature
Sled reclutched by Tri City Cycles in Loveland CO
Rear 2 Wheel Conversion.
Homemade vent kit
Rear cooler deleted, shaves weight and helps maintain proper operating temperature.
Rear Rack and taillight deleted Still have taillight and rack
Has custom 3LED Tail Light.
Have S8R7 Dyno Joe Mountain helix for HPV27 Roller Secondary Clutch
Fully Ported track
8IN Power Madd Handle bar riser
Cut down rev windshield.
Airbox deleted from body panel
front float plate not currently installed.
Skinz Trail Hand Guard's
brand new doo cover bought this year.
I am sure I am missing some stuff.
Maintenance:
Erave Valve cables replaced and readjusted
Erave Valves cleaned and gasket's replaced
Reed's cleaned.
Airbox on throttle bodies has prefilter material and one 2IN round slp style vent added to it
chaincase oil replaced
new hyfax on rear skid
all 4 shocks rebuilt by Tri City Cycles in Loveland Co.
All coolant changed when XP t-stat was installed.
Has all new Side Panel's, Hood, Bumper and trunk liner.
new fuel filter
all new relay's and have spares.
new battery last year
all recall's and updates performed by Vickery Motorsport's in Denver
sled has 07 mid altitude programming
Sled is now Black and Yellow used to be blue and yellow.
Needed stuff:
Bright light switch is broken, Y-Pipe to block gasket leaks a little other than that pull the rope and have some fun.
Thanks for looking if interested contact
Greg
970-631-9562
getitbilly@gmail.com
Also can help with delivery if fuel expenses are paid. and no lowballer's
Mods:
DynoPort Pipe
Homemade vent kit
Fully Ported track
Maintenance:
Reed's cleaned.
new fuel filter
Needed stuff:
Greg
970-631-9562
