Upgrade to Premium
Reply
  #1
Old 08-26-2018, 10:35 AM
cbc76am's Avatar
cbc76am cbc76am is offline
Currently: Cascade Mtns
cbc76am has a reputation beyond reputecbc76am has a reputation beyond reputecbc76am has a reputation beyond reputecbc76am has a reputation beyond reputecbc76am has a reputation beyond reputecbc76am has a reputation beyond reputecbc76am has a reputation beyond reputecbc76am has a reputation beyond reputecbc76am has a reputation beyond reputecbc76am has a reputation beyond reputecbc76am has a reputation beyond repute
Garage
Default CR500 cooling system design idea
Anyone that has been running a big 2T on the mtn want to contribute to my cooling system design? I'll be new to smoking on the mountain this season.
Rate this post: Yes | No
  #2
Old 08-26-2018, 02:58 PM
portgrinder portgrinder is offline
Currently: Not set.
portgrinder has a reputation beyond reputeportgrinder has a reputation beyond reputeportgrinder has a reputation beyond reputeportgrinder has a reputation beyond reputeportgrinder has a reputation beyond reputeportgrinder has a reputation beyond reputeportgrinder has a reputation beyond reputeportgrinder has a reputation beyond reputeportgrinder has a reputation beyond reputeportgrinder has a reputation beyond reputeportgrinder has a reputation beyond repute
Default
I would route your rad and cooler in series Usually only one or the other is providing cooling
The valve on the carb heater is what you want. Ideally you want all your coolant going through it when your stats are closed. See if you can get the recirculating on them down to almost nothing.
My carb is at risk of sticking wide open if the coolant gets below 70F
  #3
Old 08-26-2018, 05:50 PM
dhdey dhdey is offline
Currently: Not set.
Basic Member
dhdey has a reputation beyond reputedhdey has a reputation beyond reputedhdey has a reputation beyond reputedhdey has a reputation beyond reputedhdey has a reputation beyond reputedhdey has a reputation beyond reputedhdey has a reputation beyond reputedhdey has a reputation beyond reputedhdey has a reputation beyond reputedhdey has a reputation beyond reputedhdey has a reputation beyond repute
Default
on my cr5 i run one outlet off head direct to carb heater with no thermostat and 2nd outlet to 135 thermostat then to tunnel cooler and then they rejoin right before the water pump. no rads at all. perfect consistant temps in all conditions
  #4
Old 08-27-2018, 08:05 AM
M5- M5- is online now
Currently: Planning a build
Basic Member
M5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond repute
Default
Quote:
Is your CR500 a steelie of an AF? The Avid heater is super tight on the steelie frame depending on which carb you run.
M5
  #5
Old 08-27-2018, 08:30 AM
cbc76am's Avatar
Garage
Default
Not sure about the series vs 2 circuits that I can control, but I'll take into consideration your experience on the hill, seeing you have a lot of posts and years on these topics. Thanks for the feed back. Yes the carb heater would be tapped into the cylinder on it's own circuit with a control valve.
  #6
Old 08-27-2018, 08:31 AM
cbc76am's Avatar
Garage
Default
M5- Are you still interested in making carb heaters and selling them? I can cancel the Avid order I placed last night, it's Steel. Lectron 44HV with MRE torque plate and vforce2 is the plan.
  #7
Old 08-27-2018, 08:34 AM
cbc76am's Avatar
Garage
Default tunnel cooler that is a good match?
Quote:
Any good fits from a snowmobile that would mount well on the ARO tunnel? I found a summit 800 one on ebay that has the front facing inlet and outputs that looks like its a good fit, but haven't verified the dimensions of it yet.
  #8
Old 08-27-2018, 10:17 AM
needpowder's Avatar
needpowder needpowder is online now
Currently: dreaming of global cooling
needpowder has a reputation beyond reputeneedpowder has a reputation beyond reputeneedpowder has a reputation beyond reputeneedpowder has a reputation beyond reputeneedpowder has a reputation beyond reputeneedpowder has a reputation beyond reputeneedpowder has a reputation beyond reputeneedpowder has a reputation beyond reputeneedpowder has a reputation beyond reputeneedpowder has a reputation beyond reputeneedpowder has a reputation beyond repute
Default
I used one from an older arctic cat 570 I believe. I had mylers radiator shop in Salt Lake re-clock the eyelet so they both faced forward. Also changed them to 5/8. It’s good you’re doing this in the summer. It takes a little while to build the CR 500 just right.
__________________
2016 YZ450fx w/16 TS LT
  #9
Old 08-27-2018, 10:24 AM
Basic Member
Default
I am away from the shop for another 6 weeks so.... You may be OK, I cant remember the length of the Lectron vs a PWK I think it may actually be shorter. I've never built a heater for anyone using Adams plate. I was thinking of that for my CR5 but I am reluctant to mess with it, it just always runs perfect as is.
M5
  #10
Old 08-27-2018, 11:06 AM
cbc76am's Avatar
Garage
  #11
Old 08-29-2018, 11:41 AM
Revv Up's Avatar
Revv Up Revv Up is online now
Currently: Home of the Mountain Addiction gas can covers and custom insulated engine blankets
Revv Up has a reputation beyond reputeRevv Up has a reputation beyond reputeRevv Up has a reputation beyond reputeRevv Up has a reputation beyond reputeRevv Up has a reputation beyond reputeRevv Up has a reputation beyond reputeRevv Up has a reputation beyond reputeRevv Up has a reputation beyond reputeRevv Up has a reputation beyond reputeRevv Up has a reputation beyond reputeRevv Up has a reputation beyond repute
Click Here to Register
The Following User Says Thank You to Revv Up For This Useful Post:
cbc76am (08-29-2018)
  #12
Old 08-29-2018, 03:26 PM
Currently: Not set.
  #13
Old 08-30-2018, 10:25 AM
cbc76am's Avatar
Garage
  #14
Old 08-30-2018, 11:22 AM
wonderdummy wonderdummy is online now
Currently: Not set.
wonderdummy has a reputation beyond reputewonderdummy has a reputation beyond reputewonderdummy has a reputation beyond reputewonderdummy has a reputation beyond reputewonderdummy has a reputation beyond reputewonderdummy has a reputation beyond reputewonderdummy has a reputation beyond reputewonderdummy has a reputation beyond reputewonderdummy has a reputation beyond reputewonderdummy has a reputation beyond reputewonderdummy has a reputation beyond repute
The Following 2 Users Say Thank You to wonderdummy For This Useful Post:
cbc76am (08-30-2018), wonderdummy (09-01-2018)
  #15
Old 08-31-2018, 10:10 PM
Currently: Not set.
Basic Member
  #16
Old 08-31-2018, 10:11 PM
cbc76am's Avatar
Garage
  #17
Old 08-31-2018, 10:12 PM
Currently: Not set.
Basic Member
  #18
Old 08-31-2018, 11:51 PM
wwillf01's Avatar
wwillf01 wwillf01 is online now
Currently: Praying for snow
wwillf01 has a reputation beyond reputewwillf01 has a reputation beyond reputewwillf01 has a reputation beyond reputewwillf01 has a reputation beyond reputewwillf01 has a reputation beyond reputewwillf01 has a reputation beyond reputewwillf01 has a reputation beyond reputewwillf01 has a reputation beyond reputewwillf01 has a reputation beyond reputewwillf01 has a reputation beyond reputewwillf01 has a reputation beyond repute
  #19
Old 11-04-2018, 10:17 AM
cbc76am's Avatar
Garage
The Following 2 Users Say Thank You to cbc76am For This Useful Post:
wellfed777 (11-04-2018), wwillf01 (11-04-2018)
  #20
Old 11-04-2018, 10:47 AM
Basic Member
  #21
Old 11-04-2018, 11:23 AM
cbc76am's Avatar
Garage
  #22
Old 11-04-2018, 11:35 AM
cbc76am's Avatar
Garage
The Following User Says Thank You to cbc76am For This Useful Post:
  #23
Old 11-04-2018, 11:45 PM
wellfed777 wellfed777 is offline
Currently: Not set.
wellfed777 has a reputation beyond reputewellfed777 has a reputation beyond reputewellfed777 has a reputation beyond reputewellfed777 has a reputation beyond reputewellfed777 has a reputation beyond reputewellfed777 has a reputation beyond reputewellfed777 has a reputation beyond reputewellfed777 has a reputation beyond reputewellfed777 has a reputation beyond reputewellfed777 has a reputation beyond reputewellfed777 has a reputation beyond repute
  #24
Old 11-05-2018, 07:32 AM
wwillf01's Avatar
  #25
Old 11-05-2018, 09:31 AM
cbc76am's Avatar
Garage
wellfed777 (11-05-2018)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — cooling system Thread Starter — Larsk Forum — Polaris: 900 Replies — 2 Last Post — 10-07-2017 08:13 PM
Thread — Idea for added cooling on the Pro. Thread Starter — Matte Murder Forum — Polaris: Pro-Ride Replies — 43 Last Post — 10-25-2013 03:00 AM
Thread — Cooling system help! Thread Starter — Repsol83 Forum — Polaris: IQ Replies — 8 Last Post — 01-10-2013 09:01 AM
Thread — Cooling woes - bad idea? Thread Starter — Twostroke Forum — General Snowmobiling Replies — 5 Last Post — 02-02-2010 08:05 PM
Thread — an idea for cooling - this works! Thread Starter — fuzzydog Forum — Polaris: 900 Replies — 1 Last Post — 01-26-2010 11:25 AM
no new posts
