Upgrade to Premium
Polaris: TURBO Turbo discussion for Polaris aftermarket turbo sleds
Reply
  #1
Old 02-20-2018, 11:08 PM
Evanestad7 Evanestad7 is offline
Currently: Not set.
Basic Member
Evanestad7 has a reputation beyond reputeEvanestad7 has a reputation beyond reputeEvanestad7 has a reputation beyond reputeEvanestad7 has a reputation beyond reputeEvanestad7 has a reputation beyond reputeEvanestad7 has a reputation beyond reputeEvanestad7 has a reputation beyond reputeEvanestad7 has a reputation beyond reputeEvanestad7 has a reputation beyond reputeEvanestad7 has a reputation beyond reputeEvanestad7 has a reputation beyond repute
Default Elevation
So I am wanting to buy a new axys sled and put a turbo on it. I live in MN and have heard from people that I will not be able to safely run the turbo at my low elevation. I go out west 3 or more times a year and are planning on going out to the U.P a couple of times too, but I still want to be able to ride my sled around home too. Also I need help with the turbo that would fit someone in my situation I want one that can be ran on pump gas and av gas. Any input help thanks.
Rate this post: Yes | No
  #2
Old 02-21-2018, 09:40 AM
Willtrade Willtrade is offline
Currently: Not set.
Willtrade has a reputation beyond reputeWilltrade has a reputation beyond reputeWilltrade has a reputation beyond reputeWilltrade has a reputation beyond reputeWilltrade has a reputation beyond reputeWilltrade has a reputation beyond reputeWilltrade has a reputation beyond reputeWilltrade has a reputation beyond reputeWilltrade has a reputation beyond reputeWilltrade has a reputation beyond reputeWilltrade has a reputation beyond repute
Default
Silber is located in MN, they've tested & proven there kits at both SeaLevel and elevation. Reading through this forumn you'll find a tone of examples of Silber working well for your applications. Boondocker and MTNK systems I'm sure will fit the bill also.
The Following User Says Thank You to Willtrade For This Useful Post:
Evanestad7 (02-21-2018)
  #3
Old 02-21-2018, 09:46 AM
JJ_0909 JJ_0909 is offline
Currently: Not set.
JJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond repute
Default
Quote:
This.
Obviously, I work for Silber. (just being transparent)
You can run the 3psi spring in MN and then move up to 5 or 7 at elevation. You may need to adjust clutching slightly.
Also, I'd consider running a bit of AV gas regardless. Cheap insurance!
Otherwise, have fun!
The Following User Says Thank You to JJ_0909 For This Useful Post:
  #4
Old 02-21-2018, 11:45 AM
AKFULLTHROTTLE's Avatar
AKFULLTHROTTLE AKFULLTHROTTLE is online now
Currently: Waiting for my Polaris 850!
AKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond repute
Default
We run them from 220' to 6400' here in AK and they work perfect! We always mix in Av for safe measures.
I will say for low elevation we have had to change clutching to make it work.
__________________
Full Throttle Customs
Alaska Silber Turbos Dealer
http://www.silberturbos.com/
  #5
Old 02-21-2018, 08:29 PM
Currently: Not set.
Basic Member
Default
Quote:
Originally Posted by JJ_0909 View Post
This.
Thank you and also what mix would you do 25/75
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Curious on setups for low elevation and high elevation on 2013 silber Thread Starter — brenner1815 Forum — Polaris: TURBO Replies — 6 Last Post — 01-07-2014 08:39 PM
Thread — Elevation? Thread Starter — clatla Forum — Montana Replies — 2 Last Post — 01-22-2013 06:39 PM
Thread — ELEVATION Thread Starter — sledsnowco Forum — Polaris: Pro-Ride Replies — 3 Last Post — 11-21-2010 10:22 PM
Thread — Elevation RE Thread Starter — bradm Forum — Colorado Replies — 2 Last Post — 02-07-2009 07:14 PM
Thread — Elevation 4 Thread Starter — Samurai Forum — General Snowmobiling Replies — 80 Last Post — 11-04-2008 11:39 AM
no new posts
