Upgrade to Premium
Yamaha: 2-stroke Includes all Yamaha 2-strokes, Viper, Mountain Max, etc
Reply
  #1
Old 01-23-2018, 03:54 PM
hunterdon's Avatar
hunterdon hunterdon is offline
Currently: old iron
hunterdon has a reputation beyond reputehunterdon has a reputation beyond reputehunterdon has a reputation beyond reputehunterdon has a reputation beyond reputehunterdon has a reputation beyond reputehunterdon has a reputation beyond reputehunterdon has a reputation beyond reputehunterdon has a reputation beyond reputehunterdon has a reputation beyond reputehunterdon has a reputation beyond reputehunterdon has a reputation beyond repute
Default 85 phazer burndown
Anyone ever see both sides go down because of the pulse line from the engine to the fuel pump came off the engine end?
Rate this post: Yes | No
  #2
Old 01-26-2018, 04:07 PM
K3 K3 is offline
Currently: Dreaming of hunting
K3 has a reputation beyond reputeK3 has a reputation beyond reputeK3 has a reputation beyond reputeK3 has a reputation beyond reputeK3 has a reputation beyond reputeK3 has a reputation beyond reputeK3 has a reputation beyond reputeK3 has a reputation beyond reputeK3 has a reputation beyond reputeK3 has a reputation beyond reputeK3 has a reputation beyond repute
Default
When you say burn down- holes in pistons Or
Fuel fire or no fuel leaned out???
  #3
Old 01-27-2018, 10:45 AM
hunterdon's Avatar
Currently: old iron
Default
Hole in pto piston, broken ring land in mag piston, severe heat but no seizure, evidence of plenty of oil still on crankshaft and in bottom end. They were riding double on a warmish day and sled was working hard. Cooling belt is fine, carbs are clean. I cannot upload photo for some reason. Thanks for reply.
  #4
Old 01-27-2018, 10:58 AM
hunterdon's Avatar
Currently: old iron
Default
Ok - used photosync to upload
Click image for larger version
  #5
Old 01-27-2018, 11:10 AM
Givemeaboost's Avatar
Givemeaboost Givemeaboost is offline
Currently: Not set.
Givemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond repute
Default
Looks like it was plenty lean. I would check the roundness of the cylinders before going any further. Is the head warped too ? On a fan cooled sled you should be able to tell when they're getting hot. When they start to smell hot and lose power it's time to cool them down.
Ken.............
__________________
03 rx1 mtn with homebuilt turbo , 159 finger track , Rev tank and seat. 01 Mountain Max
The Following User Says Thank You to Givemeaboost For This Useful Post:
hunterdon (01-27-2018)
  #6
Old 01-28-2018, 12:00 PM
hunterdon's Avatar
Currently: old iron
Default
Ok - got it rebuilt - oversize bore. This sled had an Aaen single race pipe on it. I still had a stock pipe in my collection of phazer stuff so I put that on. The carbs had been drilled out for pipe use to richen the midrange so it will be way fat with the stock pipe. The sled had lots of miles with the pipe and zero issues until this meltdown. The only strange thing I found was the pulse line was off. The pulse line was really hard and brittle.
After a couple more heat cycles in the shop I will see how she does on the snow. Cheers.
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to hunterdon For This Useful Post:
K3 (01-28-2018)
  #7
Old 01-28-2018, 02:06 PM
K3 K3 is offline
Default
Glad it worked out for you all, just replaced vac line on one of mine pin hole crack by fuel pump wouldn't allow high rpm bogging thought it was fuel pump diaphragm, glad it didn't do like you!! I have another mt. Lite with pin hole piston clutch side also, how much was parts for ya @ ??? Hopefully. just piston & rings ect. we'll see when open up??? Thanx Kory
  #8
Old 01-29-2018, 12:35 PM
hunterdon's Avatar
Currently: old iron
Default
Parts were about $300.00. Oversize pistons and rings, gaskets, wrist pins and bearings, clips. Sled is running great.
The Following 2 Users Say Thank You to hunterdon For This Useful Post:
clamlake600 (02-01-2018), K3 (01-29-2018)
  #9
Old 02-01-2018, 05:14 PM
retiredpop retiredpop is online now
Currently: Not set
retiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond repute
Default
I can see that happening because basically they were riding it with very little fuel in float bowls due to the fuel pump not pumping gas so it would have been lean as heck. I had a dealer leave off the impulse line when they rebuilt a Phazer 2 and it would run until the float bowls emptied out. When it sat for a bit the bowls would fill back up again due to gravity flow through fuel pump so it would go again. Luckily I found it about the second time it quit. If they were riding it slow enough the gravity flow into the float bowls may have been just enough to stop it from quitting altogether until the meltdown occurred. I put on an Aaen quiet pipe and did the nozzle mod for the midrange after that and put on 7000 Km without a bit of trouble before we sold it.
__________________
The older I get the better I was. In fact now that I think about it I'm a legend!
Haven't outgrown my 600 yet!
The Following User Says Thank You to retiredpop For This Useful Post:
K3 (02-01-2018)
  #10
Old 02-01-2018, 08:28 PM
K3 K3 is offline
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — Looking for Ideas, M7 Burndown Thread Starter — Arctic Thunder Forum — Arctic Cat: M Series Replies — 20 Last Post — 12-17-2013 05:54 PM
Thread — 800 burndown Thread Starter — snow225 Forum — Polaris: IQ Replies — 20 Last Post — 01-13-2011 06:07 PM
Thread — Burndown aftermath... Thread Starter — DusterB Forum — Arctic Cat: M Series Replies — 6 Last Post — 10-17-2010 05:53 PM
Thread — Comp. burndown Thread Starter — Burndown1 Forum — Fouled Plug Replies — 8 Last Post — 08-13-2008 06:28 AM
Thread — xp burndown? Thread Starter — RMK900204 Forum — Ski-Doo Replies — 7 Last Post — 01-06-2008 09:23 PM
no new posts
