Upgrade to Premium
Arctic Cat: TURBO Turbo discussion for Arctic Cat aftermarket turbo sleds
Reply
  #1
Old 09-14-2017, 10:16 AM
brycter's Avatar
brycter brycter is offline
Currently: Etec and axys mods all the time
brycter has a reputation beyond reputebrycter has a reputation beyond reputebrycter has a reputation beyond reputebrycter has a reputation beyond reputebrycter has a reputation beyond reputebrycter has a reputation beyond reputebrycter has a reputation beyond reputebrycter has a reputation beyond reputebrycter has a reputation beyond reputebrycter has a reputation beyond reputebrycter has a reputation beyond repute
Default What do you guys want to see in the CAT turbo system?
Let the games begin! Pulling out the mojo. What do you guys want to see in the CAT turbo system from Turbo Performance Turbo Boyz?
We are working to get you the best turbo system for your Arctic Cat M 8000 C-Tec Motor.
Tell us what you think!
Stop by our Facebook page
visit us in www.turboperformanceind.com
Or call us 801-807-8046
Click image for larger version
__________________
Rate this post: Yes | No
The Following User Says Thank You to brycter For This Useful Post:
brycter (09-14-2017)
  #2
Old 09-14-2017, 02:51 PM
Uncle Bob Uncle Bob is offline
Currently: Not set.
Uncle Bob has a reputation beyond reputeUncle Bob has a reputation beyond reputeUncle Bob has a reputation beyond reputeUncle Bob has a reputation beyond reputeUncle Bob has a reputation beyond reputeUncle Bob has a reputation beyond reputeUncle Bob has a reputation beyond reputeUncle Bob has a reputation beyond reputeUncle Bob has a reputation beyond reputeUncle Bob has a reputation beyond reputeUncle Bob has a reputation beyond repute
Default
The must haves: External waste gate for quick response, re flashed ecu for simplicity, simplified cold air intake for consistency, ability to run at least a pump gas blend at lower elevations. A good quality all around clutch package. Ability to
quickly change springs in waste gate to adjust between 5-7-10lbs with out changing any programming.
The wish list:about 250 usable HP at 8-10 lbs, Blue tooth capable or better yet and app like the new 2018 YZ450F to quick change a map or download a re flash without having to send my ecu to another country. Maybe a water to air inter cooled air box, Something small light and compact, Not designed to produce 400 shoot climbing horse at 32 lbs but something that can help run smooth and consistent when heat soaked in the trees.
And oh ya, all this for about 4 grand
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following 2 Users Say Thank You to Uncle Bob For This Useful Post:
brycter (09-14-2017), M7-Ballz 2 the Wall (09-18-2017)
  #3
Old 09-18-2017, 03:01 PM
M7-Ballz 2 the Wall's Avatar
M7-Ballz 2 the Wall M7-Ballz 2 the Wall is offline
Currently: Every ounce counts...
M7-Ballz 2 the Wall has a brilliant futureM7-Ballz 2 the Wall has a brilliant futureM7-Ballz 2 the Wall has a brilliant futureM7-Ballz 2 the Wall has a brilliant futureM7-Ballz 2 the Wall has a brilliant futureM7-Ballz 2 the Wall has a brilliant futureM7-Ballz 2 the Wall has a brilliant futureM7-Ballz 2 the Wall has a brilliant futureM7-Ballz 2 the Wall has a brilliant futureM7-Ballz 2 the Wall has a brilliant futureM7-Ballz 2 the Wall has a brilliant future
Default
Additional to what Bob said is an oil-less turbo, stainless exhaust housing, stainless or titanium down pipe, tunnel dump exhaust. Also smooth response on the bottom with little to no turbo lag.
__________________
'18 EB-Mountain Cat 153"
'14 M600 153"
'10 TM8 - Modded Push Kit
'06 CPC 1000
The Following User Says Thank You to M7-Ballz 2 the Wall For This Useful Post:
brycter (09-20-2017)
  #4
Old 09-19-2017, 09:06 AM
Currently: Not set.
Default
I like your thinking M7-Ballz to the wall, I've had comp oil less turbos in the past and was pretty happy with the performance until it came time to get the bearings repacked. Then it became another expensive hassle, Not to mention wasting your first day of your first trip breaking in the turbo. I don't want to hijack this thread by opening up a debate, but there are options being used out there that drip injection oil in the bearing that i'm currently using and having great luck with it. I think we can agree that we just don't want an oil tank.
2 out of 2 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to Uncle Bob For This Useful Post:
M7-Ballz 2 the Wall (09-26-2017)
  #5
Old 09-26-2017, 06:40 PM
Default
Yes Bob!! No Oil tank preferred! Hated detailing with it on my Push kit, leaked all the time specially with a roll over.
__________________
'14 M600 153"
'06 CPC 1000
brycter (09-28-2017)
  #6
Old 10-19-2017, 01:19 AM
WyoBoy1000's Avatar
WyoBoy1000 WyoBoy1000 is offline
Currently: Working,
WyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond repute
Default
Quicker response and more reliable than the pro and doo for pump kits. Pull and go
That's where the money is.
Boonedicker failed horribly with side-kick to the ribs. What a joke.
__________________
Shhhh, its a secret
Assume = when you as$,u,me you make an as$ out of u and me. Think, ask, get the facts and then go forward.
  #7
Old 10-23-2017, 11:36 AM
madmax's Avatar
madmax madmax is offline
Currently: Not set.
madmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond repute
Default
What “failed horribly” on the cat side kicks? Just curious, have only seen a couple out there.
The Following User Says Thank You to madmax For This Useful Post:
brycter (10-29-2017)
  #8
Old 11-01-2017, 09:20 AM
WyoBoy1000's Avatar
Currently: Working,
Default
Laggy, hard to ride, makes them feel heavy, no clutching to speak of. Complete joke.
Had issues with every kit I've dealt with and then failures on to of that, on every kit, some boxes failed, why I started mounting them in the nose cone. Engine failures etc... Although I think 1 looked like an over heat but can't know for sure. Definately not pull and go.
The 14 mod would pull with some.
__________________
Shhhh, its a secret
The Following User Says Thank You to WyoBoy1000 For This Useful Post:
brycter (11-01-2017)
  #9
Old 11-01-2017, 09:57 AM
CO 2.0's Avatar
CO 2.0 CO 2.0 is online now
Currently: Needs to snow
CO 2.0 has a reputation beyond reputeCO 2.0 has a reputation beyond reputeCO 2.0 has a reputation beyond reputeCO 2.0 has a reputation beyond reputeCO 2.0 has a reputation beyond reputeCO 2.0 has a reputation beyond reputeCO 2.0 has a reputation beyond reputeCO 2.0 has a reputation beyond reputeCO 2.0 has a reputation beyond reputeCO 2.0 has a reputation beyond reputeCO 2.0 has a reputation beyond repute
Default
Agreed. You couldn't pay me to ride the suzuki boondocker kit. Horrible lag compared to my axys silber. I've said it multiple times now. I won't buy a turbo without a reflashed factory ecu.
__________________
'18 Mountain Cat 153, '16 Axys 3" PC 153 Silber (Sold), '19 Alpha
http://www.weknowsnow.com
The Following User Says Thank You to CO 2.0 For This Useful Post:
  #10
Old 11-01-2017, 03:46 PM
Rinker's Avatar
Rinker Rinker is offline
Currently: Not set.
Rinker has a reputation beyond reputeRinker has a reputation beyond reputeRinker has a reputation beyond reputeRinker has a reputation beyond reputeRinker has a reputation beyond reputeRinker has a reputation beyond reputeRinker has a reputation beyond reputeRinker has a reputation beyond reputeRinker has a reputation beyond reputeRinker has a reputation beyond reputeRinker has a reputation beyond repute
  #11
Old 11-04-2017, 10:12 AM
madmax's Avatar
Currently: Not set.
Click Here to Register
  #12
Old 11-04-2017, 05:10 PM
CO 2.0's Avatar
  #13
Old 11-05-2017, 08:58 AM
Sunvang Sunvang is offline
Currently: Not set.
Sunvang has a reputation beyond reputeSunvang has a reputation beyond reputeSunvang has a reputation beyond reputeSunvang has a reputation beyond reputeSunvang has a reputation beyond reputeSunvang has a reputation beyond reputeSunvang has a reputation beyond reputeSunvang has a reputation beyond reputeSunvang has a reputation beyond reputeSunvang has a reputation beyond reputeSunvang has a reputation beyond repute
  #14
Old 11-05-2017, 09:01 AM
nm2708 nm2708 is online now
Currently: Not set.
nm2708 has a reputation beyond reputenm2708 has a reputation beyond reputenm2708 has a reputation beyond reputenm2708 has a reputation beyond reputenm2708 has a reputation beyond reputenm2708 has a reputation beyond reputenm2708 has a reputation beyond reputenm2708 has a reputation beyond reputenm2708 has a reputation beyond reputenm2708 has a reputation beyond reputenm2708 has a reputation beyond repute
  #15
Old 11-05-2017, 09:48 AM
Motorbreath_ Motorbreath_ is online now
Currently: Shoveling snow! :D
Basic Member
Motorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond repute
  #16
Old 11-06-2017, 02:12 AM
Currently: Not set.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 2012 VOHK Boondocker Turbo Pro / or just turbo system Thread Starter — BrachtMotosports116 Forum — Polaris (Swapmeet) Replies — 0 Last Post — 03-23-2015 01:41 PM
Thread — WTT: my full Arctic cat m1000 slp exhaust system for your speedwerx exhaust system Thread Starter — rnigro84 Forum — WTB (Swapmeet) Replies — 1 Last Post — 12-05-2014 07:32 AM
Thread — Aerocharger 2012 Arctic-Cat Turbo System details Thread Starter — Aerocharger_Brad Forum — Arctic Cat: TURBO Replies — 1 Last Post — 12-22-2012 08:19 PM
Thread — Hey guys....sellin my M1000 Turbo..pics & info in Swap under Arctic Cat Thread Starter — nothin serious Forum — General Snowmobiling Replies — 2 Last Post — 01-28-2010 08:04 PM
Thread — wtb CPI king cat turbo system Thread Starter — zrt1 Forum — Turbos/Superchargers (Swapmeet) Replies — 5 Last Post — 09-11-2009 09:35 AM
no new posts
