Upgrade to Premium
Ski-Doo: XP Sleds 2007.5-current, all models in the XP, XT and XR chassis
Reply
  #1
Old 04-25-2017, 11:25 PM
mx100 mx100 is offline
Currently: Loving the XP chassis!!
mx100 has a reputation beyond reputemx100 has a reputation beyond reputemx100 has a reputation beyond reputemx100 has a reputation beyond reputemx100 has a reputation beyond reputemx100 has a reputation beyond reputemx100 has a reputation beyond reputemx100 has a reputation beyond reputemx100 has a reputation beyond reputemx100 has a reputation beyond reputemx100 has a reputation beyond repute
Default How to adjust the stock rear suspension on an 09 XP with a 174 3"
This sled is an 09 and had a 163x2.5 track with the upgraded 2010 skid front shock and the scissors relocate kit on it.
I just recently installed a 174x3" track with 174 Ice Age rails. I flipped the bracket over and re drilled the hole for the skid front mount,(Down and back), I dropped the skid rear mount down 1 1/8", I did NOT reinstall the scissors relocate. I installed new Heavy Duty torsion springs, and put 4 newer shocks, (600 mi. on them) on the sled.
It feels like it trenches and doesn't have any ski pressure, when riding in deep snow, it carries the ski's fairly high, and feels difficult to ride. On the harder pack snow it seams to push really really hard, again feels like no ski preasure. Limiter strap is at it's longest. I have rode other 174x3" sleds, and I don't remember them pushing this hard.
I am just looking for advice, or recomendations from guys that have tried this 174x3" setup with stockish suspension, to see what you did to get your suspension to work. Thank.
Rate this post: Yes | No
  #2
Old 04-26-2017, 11:45 PM
eddy's Avatar
eddy eddy is offline
Currently: Dirt Bike Season!
eddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond repute
Default Push
Shorten the limiter strap and reduce the spring tension on the front shock.
  #3
Old 04-29-2017, 09:19 PM
FEZ FEZ is offline
Currently: Mechanic for and Advisor to SHR
Basic Member
FEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond repute
Default
How much do you weigh?
I am 215# not suited and I found the heavy torsion springs to be too much. I run stock XM springs on my '09.
They are also 3lbs lighter.
  #4
Old 05-01-2017, 03:19 PM
BIG JOHN's Avatar
BIG JOHN BIG JOHN is offline
Currently: making Summits bettersince 1997
BIG JOHN has a reputation beyond reputeBIG JOHN has a reputation beyond reputeBIG JOHN has a reputation beyond reputeBIG JOHN has a reputation beyond reputeBIG JOHN has a reputation beyond reputeBIG JOHN has a reputation beyond reputeBIG JOHN has a reputation beyond reputeBIG JOHN has a reputation beyond reputeBIG JOHN has a reputation beyond reputeBIG JOHN has a reputation beyond reputeBIG JOHN has a reputation beyond repute
Default
set limiter so there is little/no free play at rest in garage...
get DS2 or DS3 skis
set center shock on lowest preload-BJ
__________________
sledheadracing.net
SLED HEAD RACING
612-718-3861
"The BEST BB motor I ever rode"
SHR860R/SHR880R carb/ETEC (REV/XP/XM)
SHR850 180 kit/SHR921 (gen4)
MPI/SHR 850 turbo/SHR adjustable weights/kits
  #5
Old 05-01-2017, 10:28 PM
Default
I weigh 265lbs with no gear. I am running DS2 ski's. The limiter is all the way out, and there is no sag or play in the limiter while resting on the shop floor, (It is tight). The front skid shock is at it's softest setting. The rear heavy duty torsion springs are on the stiffest.
When I pick the track up off the floor in the shop and set it back down, the front of the track touches the floor just barely before the middle/back touches the floor. It really almost touches the whole track at the same time, but the front is just a hair sooner.
  #6
Old 05-02-2017, 11:55 AM
eddy's Avatar
Default Push
Increase preload on the ski shocks and/or suck in the limiter one step at a time until you have some pressure on the skis.
Between the new skid frame mounting points and the profile of the new rails there may be some geometry changes you have to compensate for. Compare your set up to a 2016 T3 and try to replicate what the OEM did.
  #7
Old 05-02-2017, 03:21 PM
BIG JOHN's Avatar
Default
OK
pull limiter up 1, set center shock spring preload at minimum, retest-BJ
__________________
sledheadracing.net
SLED HEAD RACING
612-718-3861
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — WTB: XM 174" rear bumper Thread Starter — BigAir Forum — WTB (Swapmeet) Replies — 0 Last Post — 04-03-2017 01:37 AM
Thread — FS Yamaha Nytro Timbersled suspension 174" Thread Starter — yamiman Forum — Suspension/Shocks (Swapmeet) Replies — 0 Last Post — 02-28-2014 07:40 PM
Thread — stock m7 rear suspension Thread Starter — dgreet77 Forum — Suspension/Shocks (Swapmeet) Replies — 9 Last Post — 01-21-2014 10:04 PM
Thread — NEEDED ASAP! Polaris RMK 151" Edge Rear shock on Rear suspension Thread Starter — Summitstef Forum — Suspension/Shocks (Swapmeet) Replies — 2 Last Post — 12-24-2011 04:17 PM
Thread — 2009 Dragon 163" rear suspension/2006 144 RMK rear suspension Thread Starter — boondocker1 Forum — Suspension/Shocks (Swapmeet) Replies — 8 Last Post — 08-20-2010 02:03 PM
no new posts
