Upgrade to Premium
Ski-Doo: REV Sleds 2004.5-200, all models in the REV chassis
Reply
  #1
Old 02-07-2017, 12:46 PM
lancelarue lancelarue is offline
Currently: waiting for snow!!
lancelarue has a reputation beyond reputelancelarue has a reputation beyond reputelancelarue has a reputation beyond reputelancelarue has a reputation beyond reputelancelarue has a reputation beyond reputelancelarue has a reputation beyond reputelancelarue has a reputation beyond reputelancelarue has a reputation beyond reputelancelarue has a reputation beyond reputelancelarue has a reputation beyond reputelancelarue has a reputation beyond repute
Default Jackshafts
Anyone have experience with jackshaft flex problems in the Rev Summit chassis?
I was wondering if the jackshaft in the "X" models which is gun drilled chrome moly is worse than the solid shaft in the Adrenaline models? These shafts were the same in the 06' and the 07'.
Thanks
__________________
Old faithful :06' Summit X W/163" flex,2 wheels in rear, big drop & roll. 860R, 05' electronics, 46 mm Lectrons, custom airbox, lots of air, SLP single, Paragon, Mtn Tamer rear w/ floats all the away around,extra cooling tubes in tunnel, premix, 5 gal race tank, >
Trail sled: 07' 151" stock except 860 & paragon, other stuff
Rate this post: Yes | No
  #2
Old 02-28-2018, 07:40 PM
Default Shaft flex
Thanks
I'm answering my own question!
So: FYI !!!!!
Thought I would try the C-3 belt drive again with some changes/stiffeners.
Same results except this time it doesn't bend the idler support bracket, under big torque I can see belt start to walk of to outside on top / jackshaft and it starts to eat on the flange @ side of idler wheel. Tried different spacing locations etc., doesn't matter. The harder I pull on it the further it goes.
__________________
  #3
Old 03-01-2018, 08:04 PM
sledsrock sledsrock is offline
Currently: SUMMER SUCKS!
sledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond repute
Default
What kind of power you suppose you’re putting to this shaft? I wonder how much flex my 880 is creating.
  #4
Old 03-02-2018, 12:04 PM
Default drive train flex
Don't know what it's putting out. Haven't had it on the dyno yet. To be honest it really doesn't feel that impressive yet. Maybe a gallon of gas through new engine build. So still tight lot's of oil etc. This is an 860. Last year on the 880 had the same problems exactly only was having issues with the idler wheel support bracket. Fixed that so put belt drive back on thinking I was good to go. NOT!
Here's an easy test> better with two guys, on track stand ready to go, position where you can watch top gear with good light etc. Open it up and watch belt on top gear for side movement. Then do it again and make it pull against the brake real quick if you want to really load it up. You could also record it on your phone / camera and just replay to watch. I'm thinking this may be isolated to the rev chassis as without chain case cover on the top of the inner case / bearing area is pretty wimpy beings it's so far from support.
Took it all off, back to chain & gears. Hurts to do it as I really like the belt drive but I don't have time to build what it takes to fix it right now.
__________________
  #5
Old 03-02-2018, 08:16 PM
Default
Hmmm. Me running chain still too BUT have the billet SPI case. Maybe I’m good with this case and cover.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — Broken Jackshafts! 14 and 15 Thread Starter — justinwmx20406 Forum — Arctic Cat: Proclimb M Replies — 7 Last Post — 01-11-2017 06:30 AM
Thread — broken jackshafts Thread Starter — richardderkevorkian Forum — Arctic Cat: Proclimb M Replies — 47 Last Post — 02-24-2015 07:36 PM
Thread — WTB jackshafts Thread Starter — late96 Forum — Clutch/Drive Train/Belt (Swapmeet) Replies — 0 Last Post — 11-01-2012 05:35 AM
Thread — jackshafts Thread Starter — Trip Forum — Polaris: GEN 2 Replies — 2 Last Post — 02-28-2012 08:53 PM
Thread — Driven Pullies and Jackshafts Thread Starter — 550iq Forum — Ski-Doo: XP Sleds Replies — 7 Last Post — 11-29-2010 08:33 AM
