Upgrade to Premium
Polaris: GEN 1 and older 1998 and older, all models in the Gen 1 Indy chassis and older chassis models
Reply
  #1
Old 01-24-2017, 11:40 PM
Greggeer89 Greggeer89 is offline
Currently: Not set.
Basic Member
Greggeer89 is an unknown quantity at this point
Default 97 rmk 700 no spark
Does anyone know if there is a coil/cdi box off of a different machine that will work on my 1997 rmk700 or if i can swap out a newer ignition system
Rate this post: Yes | No
  #2
Old 02-07-2017, 11:18 AM
SixtySevenGT's Avatar
SixtySevenGT SixtySevenGT is offline
Currently: Building Sleds
SixtySevenGT has a reputation beyond reputeSixtySevenGT has a reputation beyond reputeSixtySevenGT has a reputation beyond reputeSixtySevenGT has a reputation beyond reputeSixtySevenGT has a reputation beyond reputeSixtySevenGT has a reputation beyond reputeSixtySevenGT has a reputation beyond reputeSixtySevenGT has a reputation beyond reputeSixtySevenGT has a reputation beyond reputeSixtySevenGT has a reputation beyond reputeSixtySevenGT has a reputation beyond repute
Default Newer Ignition
The 97 - 98 600 / 700 Twins used the all in one
Igntion.
You can swap this out for the newer 2000 - 2001
700 Ignition setup. You will need the MAG componet also.
Those older Ignition modules tend to be expensive and ony avaliable used as far as I know.
__________________
"Always Drink Upstream from the Herd"
  #3
Old 03-10-2017, 08:30 PM
uSoTiNy uSoTiNy is offline
Currently: Not set.
Basic Member
uSoTiNy has a reputation beyond reputeuSoTiNy has a reputation beyond reputeuSoTiNy has a reputation beyond reputeuSoTiNy has a reputation beyond reputeuSoTiNy has a reputation beyond reputeuSoTiNy has a reputation beyond reputeuSoTiNy has a reputation beyond reputeuSoTiNy has a reputation beyond reputeuSoTiNy has a reputation beyond reputeuSoTiNy has a reputation beyond reputeuSoTiNy has a reputation beyond repute
Default
I think I have one of those somewhere... I know in my 600 I used a 440 xcr cdi for drag racing as it gave more power. I have that one still as well. I think my sled was a 98 though. Send me a pic of yours I have a few different cdis around
  #4
Old 11-17-2017, 09:12 PM
indyseven indyseven is offline
Currently: Not set.
indyseven has a reputation beyond reputeindyseven has a reputation beyond reputeindyseven has a reputation beyond reputeindyseven has a reputation beyond reputeindyseven has a reputation beyond reputeindyseven has a reputation beyond reputeindyseven has a reputation beyond reputeindyseven has a reputation beyond reputeindyseven has a reputation beyond reputeindyseven has a reputation beyond reputeindyseven has a reputation beyond repute
Default
Check the solder points on the mag pick up. I just had the same issue and thats what I found. you will have to break the glue off and you will probably find the solder joint is broken. Clean it, solder it and ride some more!
The Following User Says Thank You to indyseven For This Useful Post:
WHEREDAFUGAWEE (12-15-2017)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 1999 Ski Doo Summit 700 136/RMK 700 144 Thread Starter — dubeffect Forum — Ski-Doo (Swapmeet) Replies — 3 Last Post — 11-18-2013 12:01 PM
Thread — 2002 RMK 700 AND 2005 RMK 700 Thread Starter — smitfire Forum — Polaris: EDGE Replies — 11 Last Post — 10-07-2011 04:22 PM
Thread — 2002 RMK 700 AND 2005 RMK 700 Thread Starter — smitfire Forum — Polaris: EDGE Replies — 1 Last Post — 10-05-2011 06:36 AM
Thread — 2000 Mountain Max 700 & 2001 RMK 700, Trailer Thread Starter — colorado rmk addict Forum — Yamaha (Swapmeet) Replies — 0 Last Post — 08-28-2011 05:39 PM
Thread — 2001 700 RMK & 2000 700 Mtn Max, plus trailer Thread Starter — colorado rmk addict Forum — Polaris (Swapmeet) Replies — 0 Last Post — 08-28-2011 05:32 PM
no new posts
