Upgrade to Premium
Polaris: EDGE 2002-2005, all models in the Edge chassis
Reply
  #1
Old 01-10-2017, 08:29 AM
blackhillsrmk's Avatar
blackhillsrmk blackhillsrmk is online now
Currently: Not set.
blackhillsrmk has a reputation beyond reputeblackhillsrmk has a reputation beyond reputeblackhillsrmk has a reputation beyond reputeblackhillsrmk has a reputation beyond reputeblackhillsrmk has a reputation beyond reputeblackhillsrmk has a reputation beyond reputeblackhillsrmk has a reputation beyond reputeblackhillsrmk has a reputation beyond reputeblackhillsrmk has a reputation beyond reputeblackhillsrmk has a reputation beyond reputeblackhillsrmk has a reputation beyond repute
Default 2002 Chaincase replacement
Swapping out the chain case on a 2002 RMK. Looking for any information, dos or don'ts, tips or tricks. Looks pretty simple, but any advice on simplifying the process would be appreciated.
Rate this post: Yes | No
The Following User Says Thank You to blackhillsrmk For This Useful Post:
rmk8001 (10-01-2017)
  #2
Old 01-10-2017, 11:50 AM
Mark's RMK's Avatar
Mark's RMK Mark's RMK is offline
Currently: Not set.
Mark's RMK has a reputation beyond reputeMark's RMK has a reputation beyond reputeMark's RMK has a reputation beyond reputeMark's RMK has a reputation beyond reputeMark's RMK has a reputation beyond reputeMark's RMK has a reputation beyond reputeMark's RMK has a reputation beyond reputeMark's RMK has a reputation beyond reputeMark's RMK has a reputation beyond reputeMark's RMK has a reputation beyond reputeMark's RMK has a reputation beyond repute
Default Chaincase
Move to the newer Pro-X style with the better brake.
It's also used on the Vertical Escapes.
Better chain tensioner.
Make sure you use new bearings and seals and replace the speedometer drive bearing/seal as well.
__________________
2013 800 Pro RMK 155 ES, Burandt boards, Timbersled A-arms, NXT Level WS Bag, skid plate, VE belt guard, Team Tied Clutch, MTX wts, SLP Hot Air Eliminators, Mike Taylor Footwell Vents, Powder Keg tank/pack, Rox Flex Tec II Handguards.
Wife's Sled - 2012 Yamaha Apex XTX 144" EPS, Earth X battery, Yamaha Handguards, cable scratchers
2015 600 RMK 155, ES, skid plate, MTX wts
The Following User Says Thank You to Mark's RMK For This Useful Post:
blackhillsrmk (01-17-2017)
  #3
Old 01-10-2017, 12:27 PM
sled_guy's Avatar
sled_guy sled_guy is offline
Currently: In limbo
sled_guy has a reputation beyond reputesled_guy has a reputation beyond reputesled_guy has a reputation beyond reputesled_guy has a reputation beyond reputesled_guy has a reputation beyond reputesled_guy has a reputation beyond reputesled_guy has a reputation beyond reputesled_guy has a reputation beyond reputesled_guy has a reputation beyond reputesled_guy has a reputation beyond reputesled_guy has a reputation beyond repute
Default
I like Mark's RMK suggestion, but this change is not simple. The Escape chain case is quite different than the standard RMK one. The brake is better, but on an 02 I'm not sure it is worth the effort to make the change.
sled_guy
__________________
"Sorry, I thought you could ride"
The Following User Says Thank You to sled_guy For This Useful Post:
  #4
Old 01-29-2017, 02:04 PM
whoisthatguy's Avatar
whoisthatguy whoisthatguy is offline
Currently: Not set.
whoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond repute
Default
Putting a new bearing on the clutch end of the drive axle, requires heating up the bearing with a torch and setting it on before it cools. Then there is the issue of getting the track on and threading the drive axle back into place. It is a real workout. If the sled has over 3000 miles, the track probably has missing lugs and the lug tips are worn down to a point. Which then means you might want to find a camoplast challenger that was made for Arctic Cats. It is a major traction upgrade and show to you how pathetic the stock Polaris series IV track is.
The Following User Says Thank You to whoisthatguy For This Useful Post:
blackhillsrmk (02-02-2017)
  #5
Old 10-01-2017, 09:50 AM
Batwolf Batwolf is offline
Currently: Not set.
Batwolf is an unknown quantity at this point
Default
What's better about the Challenger track? Are the lugs more rigid? I know the series IV has 4 lugs staggered across the width of the track, where as the challenger track has 3 wider lugs staggered. Although a little shorter lugs, the Challenger really is better than a good condition series IV?
  #6
Old 10-01-2017, 11:31 PM
Currently: Not set.
Default
Quote:
Since the snow is trapped between the top and bottom of the lug, and gets pushed out the side of the lug, the wider the lug, the further the distance the snow has to move in order to no longer be resisting the pressure of the lug. With four lugs across, the lug width on a 15" wide track is about 3.75", with the average distance that the snow has to travel to be expelled is 3.75"/4 = 0.94". With 3 lugs across, the lug width is 5" with the average distance of snow travel is 1.25". So the 3 lug track is 1.25/0.94 = 1.33 times more efficient than a 4 lug series IV track. Some camoplast challenger lugs are also cupped, which helps trap the snow much better than a flat faced Series IV lug. Which further increases the track efficiency. When you put a CC 3 cupped lug track on, you will immediately notice the much stronger pull in deep powder.
  #7
Old 10-02-2017, 06:55 AM
Currently: Not set.
Default
Thanks for opening my eyes on that; I hadn't given the topic much thought before. I honestly feel like my common sense esaped me there for a little bit, but I get it now. Prolly gonna stick with my IV this season, but will probably look into changing next year maybe.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — M1000 reed replacement;TPS adj; drive shaft bearing replacement; tank replacement Thread Starter — Sledbrain2 Forum — Arctic Cat: M Series Replies — 0 Last Post — 01-16-2016 09:38 PM
Thread — Broke a chaincase in Wolf Creek, need a replacement ASAP... Thread Starter — Murph Forum — Polaris: Pro-Ride Replies — 10 Last Post — 03-05-2015 11:39 PM
Thread — 2002 carb replacement Thread Starter — JesseTemple Forum — Ski-Doo: ZX Sleds Replies — 1 Last Post — 02-13-2012 12:22 AM
Thread — 2002 xc 700 edge x chaincase Thread Starter — 2007dragonman Forum — Polaris: EDGE Replies — 2 Last Post — 12-04-2011 10:04 PM
Thread — 2002 RMK 800 Pull Start Replacement Thread Starter — fleafighter Forum — Polaris Replies — 8 Last Post — 02-22-2009 12:36 PM
no new posts
