Upgrade to Premium
Trucks and Trailers Towing and hauling your sleds
Reply
  #1
Old 05-31-2016, 12:11 PM
bhoth's Avatar
bhoth bhoth is offline
Currently: Waiting for snow!
bhoth has a reputation beyond reputebhoth has a reputation beyond reputebhoth has a reputation beyond reputebhoth has a reputation beyond reputebhoth has a reputation beyond reputebhoth has a reputation beyond reputebhoth has a reputation beyond reputebhoth has a reputation beyond reputebhoth has a reputation beyond reputebhoth has a reputation beyond reputebhoth has a reputation beyond repute
Default Best lock to use for enclosed trailer puck or other?
Hi All, just wondering what you you all use to lock the ramp doors on your enclosed trailer. I bought cheap puck locks and they freeze up badly and also are rusting like crazy too.
I stopped using them before the season was over because I was paranoid that I was going to get locked out of my trailer.
What do you all use that works?
Thanks!
__________________
2014 M8000 Sno Pro 153/ SLP Can, SLP Mohawk Skis, BDX Anti-stab, TKI Belt drive w/2.52 ratio, Rox 2" rolled forward. 2016 38" front end.
2009 M8 LE 153/MBRP can, Simmons Gen 1 skis, BDX Anti-stab, BDX wide bearing in Diamond Drive, 2010 Mountain seat
Rate this post: Yes | No
  #2
Old 05-31-2016, 01:33 PM
summ8rmk's Avatar
summ8rmk summ8rmk is online now
Currently: Alpha Hawk!
summ8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond repute
Default
Regular master lock and full coverage INS.
Use a dry graphite lubricant once a year. Don't tow trailer with locks on unless the roads are dry.
I put the warm dry locks on at the snopark.
GS6
1 out of 1 members found this post helpful. Rate this post: Yes | No
  #3
Old 05-31-2016, 05:22 PM
DUKHTR3 DUKHTR3 is offline
Currently: Not set.
DUKHTR3 has a reputation beyond reputeDUKHTR3 has a reputation beyond reputeDUKHTR3 has a reputation beyond reputeDUKHTR3 has a reputation beyond reputeDUKHTR3 has a reputation beyond reputeDUKHTR3 has a reputation beyond reputeDUKHTR3 has a reputation beyond reputeDUKHTR3 has a reputation beyond reputeDUKHTR3 has a reputation beyond reputeDUKHTR3 has a reputation beyond reputeDUKHTR3 has a reputation beyond repute
Default
I have been using the master lock 6121 for the last 5 years and have never had them freeze. I have them on the trailer all the time
Sent from my E6782 using Tapatalk
The Following User Says Thank You to DUKHTR3 For This Useful Post:
bhoth (05-31-2016)
  #4
Old 06-02-2016, 03:13 PM
milehighassassin's Avatar
milehighassassin milehighassassin is offline
Currently: Motor is complete!!!
Moderator: Premium Member
milehighassassin has a reputation beyond reputemilehighassassin has a reputation beyond reputemilehighassassin has a reputation beyond reputemilehighassassin has a reputation beyond reputemilehighassassin has a reputation beyond reputemilehighassassin has a reputation beyond reputemilehighassassin has a reputation beyond reputemilehighassassin has a reputation beyond reputemilehighassassin has a reputation beyond reputemilehighassassin has a reputation beyond reputemilehighassassin has a reputation beyond repute
Garage
Default
I like these:
http://www.boltlock.com/vehicle-match/
They get keyed to work with your truck key. Then you just have to carry one set of key and never have to worry about not having your key with you. Obviously if you tow with different vehicles, it could be an issue. Once you key it, it is forever on that key.
__________________
Need to get rid of a STRAIGHT IQ 163" tunnel and tub. Cheap!!
2 out of 2 members found this post helpful. Rate this post: Yes | No
  #5
Old 06-06-2016, 12:06 PM
Mark's RMK's Avatar
Mark's RMK Mark's RMK is offline
Currently: Not set.
Mark's RMK has a reputation beyond reputeMark's RMK has a reputation beyond reputeMark's RMK has a reputation beyond reputeMark's RMK has a reputation beyond reputeMark's RMK has a reputation beyond reputeMark's RMK has a reputation beyond reputeMark's RMK has a reputation beyond reputeMark's RMK has a reputation beyond reputeMark's RMK has a reputation beyond reputeMark's RMK has a reputation beyond reputeMark's RMK has a reputation beyond repute
Default Bolt Locks
Quote:
Originally Posted by milehighassassin View Post
I like these:
Do you have experience with the different styles? I was thinking of the padlocks for the door/ramps on the enclosed trailer and they also have pin locks for the hitch?
__________________
2013 800 Pro RMK 155 ES, Burandt boards, Timbersled A-arms, NXT Level WS Bag, skid plate, VE belt guard, Team Tied Clutch, MTX wts, SLP Hot Air Eliminators, Mike Taylor Footwell Vents, Powder Keg tank/pack, Rox Flex Tec II Handguards.
Wife's Sled - 2012 Yamaha Apex XTX 144" EPS, Earth X battery, Yamaha Handguards, cable scratchers
2015 600 RMK 155, ES, skid plate, MTX wts
  #6
Old 06-07-2016, 05:38 PM
Garage
Default
I don't have much. I bought a set for my parents, they use the pin lock and a regular lock. I'd imagine they all work the same.
__________________
  #7
Old 06-11-2016, 05:13 PM
bhoth's Avatar
Default
Anyone else? I really like the idea of the puck style luck just need one that is enclosed or have some kind of cover to keep it out of the weather.
__________________
  #8
Old 06-13-2018, 01:55 AM
Jelysher Jelysher is offline
Currently: Not set.
Basic Member
Jelysher is an unknown quantity at this point
Talking
Quote:
Maybe it's too late.I'd say it depends on the cable. We used to lock our old I/O up with something akin to a high end bike cable through the wheels. Forgot it once and drove away. Ripped that cable apart without much fuss.I have used a coupler lock on my old MC trailer. It was not that style, but rather, an ordinary U in the locking pin. Doesn't work on my new trailer, for which I need one like what is posted above. Now, I continue to use DT Coupler (Diversi-Tech) locks https://secretstorages.com/best-lock...storage-units/ on all of my trailers - dump, skidsteer, utility, enclosed and boat trailers without fail. Had a buddy want to use one of my trailers while I was out of town and told him if he could get the lock off he could use it. So being a rancher, he took a grinder, sledge and various other methods to the lock and it didn't give. So far so good, average price around $45.00. By the way my mastercraft trailer has the UFP style coupler as well and it works great on there.
And here's another solution, as an alternative
Hope it helps.Good Luck
  #9
Old 06-13-2018, 01:59 PM
Jaynelson Jaynelson is online now
Currently: Not set.
Jaynelson has a reputation beyond reputeJaynelson has a reputation beyond reputeJaynelson has a reputation beyond reputeJaynelson has a reputation beyond reputeJaynelson has a reputation beyond reputeJaynelson has a reputation beyond reputeJaynelson has a reputation beyond reputeJaynelson has a reputation beyond reputeJaynelson has a reputation beyond reputeJaynelson has a reputation beyond reputeJaynelson has a reputation beyond repute
Default
In the age where you have a video phone/supercomputer in your pocket.....doesn't it seems more than slightly insane that the enclosed manufacturers haven't yet figured out an interior lock? So you can lock the ramp doors and exit via the man door? Or any system a little more slick than carrying padlocks around to lock up your brand new trailer?
The Following User Says Thank You to Jaynelson For This Useful Post:
summ8rmk (06-13-2018)
  #10
Old 06-14-2018, 07:59 AM
Blk88GT's Avatar
Blk88GT Blk88GT is offline
Currently: Patiently waiting for my '19
Blk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond repute
The Following 2 Users Say Thank You to Blk88GT For This Useful Post:
Jaynelson (06-14-2018), summ8rmk (06-14-2018)
  #11
Old 06-21-2018, 09:46 PM
szotty szotty is offline
Currently: Winning
Basic Member
szotty has a reputation beyond reputeszotty has a reputation beyond reputeszotty has a reputation beyond reputeszotty has a reputation beyond reputeszotty has a reputation beyond reputeszotty has a reputation beyond reputeszotty has a reputation beyond reputeszotty has a reputation beyond reputeszotty has a reputation beyond reputeszotty has a reputation beyond reputeszotty has a reputation beyond repute
Click Here to Register
  #12
Old 06-23-2018, 05:08 PM
Currently: Not set.
  #13
Old 10-16-2018, 09:37 AM
Carvedout Carvedout is offline
Currently: Not set.
Basic Member
Carvedout is an unknown quantity at this point
  #14
Old 10-16-2018, 10:24 AM
FatDogX's Avatar
FatDogX FatDogX is offline
Currently: ND. Meatball Crew / Polaris Ambassador
FatDogX has a reputation beyond reputeFatDogX has a reputation beyond reputeFatDogX has a reputation beyond reputeFatDogX has a reputation beyond reputeFatDogX has a reputation beyond reputeFatDogX has a reputation beyond reputeFatDogX has a reputation beyond reputeFatDogX has a reputation beyond reputeFatDogX has a reputation beyond reputeFatDogX has a reputation beyond reputeFatDogX has a reputation beyond repute
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Lost Lock (puck style) @ Francis Wallace snopark Thread Starter — redneckj Forum — Idaho Replies — 1 Last Post — 01-24-2016 08:18 AM
Thread — Lock your trailer at Togwotee Mt. Lodge Thread Starter — jorgy Forum — Wyoming Replies — 12 Last Post — 01-13-2015 12:22 PM
Thread — 2014 Mission 30' enclosed trailer car hauler snowmobile trailer 10000 lb capacity Thread Starter — awixi Forum — Trucks and Trailers Replies — 5 Last Post — 11-05-2014 07:28 PM
Thread — Need a Trailer Door Lock/Latch for Enclosed Thread Starter — Mortgage Paul Forum — General Snowmobiling Replies — 0 Last Post — 11-26-2009 09:33 PM
Thread — WTB Enclosed Trailer, Cargo Trailer Thread Starter — mtnjunkie Forum — Trailer/Transport (Swapmeet) Replies — 2 Last Post — 06-19-2008 01:50 AM
no new posts
