Upgrade to Premium
Polaris: GEN 2 1999-2001, all models in the Gen 2 chassis
Reply
  #1
Old 01-05-2016, 03:52 PM
preclatton preclatton is offline
Currently: Not set.
Basic Member
preclatton has a reputation beyond reputepreclatton has a reputation beyond reputepreclatton has a reputation beyond reputepreclatton has a reputation beyond reputepreclatton has a reputation beyond reputepreclatton has a reputation beyond reputepreclatton has a reputation beyond reputepreclatton has a reputation beyond reputepreclatton has a reputation beyond reputepreclatton has a reputation beyond reputepreclatton has a reputation beyond repute
Default 99 600 RMK high idle
Hi,
Last year I purchased a 99 600 RMK in excellent, low mileage condition. The sled has sit quite a bit and this winter is the first time we've had enough snow to finally ride it. The idle is very high (3,200 rpm). Going through a ton of fuel. The idle does drop if I flip on the choke. Before I tear into this, kind of new to snowmobiles, any ideas on what is causing the high idle. I am suspecting a plugged pilot jet, since the sled has been sitting quite a bit.
Rate this post: Yes | No
  #2
Old 01-05-2016, 03:53 PM
Currently: Not set.
Basic Member
Default
PS...I've tried the idle screw on each carb...no change
  #3
Old 01-05-2016, 04:08 PM
bkpa's Avatar
bkpa bkpa is offline
Currently: Not set.
bkpa has a reputation beyond reputebkpa has a reputation beyond reputebkpa has a reputation beyond reputebkpa has a reputation beyond reputebkpa has a reputation beyond reputebkpa has a reputation beyond reputebkpa has a reputation beyond reputebkpa has a reputation beyond reputebkpa has a reputation beyond reputebkpa has a reputation beyond reputebkpa has a reputation beyond repute
Default
Carb boots?
  #4
Old 01-05-2016, 04:30 PM
Scott's Avatar
Scott Scott is offline
Currently: ACTIVELY defend your right to ride.
Polaris & Montana Moderator
Scott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond repute
Garage
Default
Fire it up.
Open the hood.
Spray some ether or carb cleaner around the base gaskets all the way around the cylinders and carb boots.
Does it make it idle even higher? If so, you have a base gasket or carb boot leak.
__________________
OEM parts from Free Agent
Ambassador for:
FB & IG: Scott Stiegler
Honestly, Honey!!! The shop paid for these mods. They sponsor me now. Really!
Check out these cool products:
  #5
Old 01-05-2016, 05:10 PM
Currently: Not set.
Basic Member
Default
Okay I can check those things. If I don't get any positive results, could a plugged pilot jet cause these symptoms.
  #6
Old 01-06-2016, 10:33 AM
Snow Duck's Avatar
Snow Duck Snow Duck is offline
Currently: Trees are not for me!!or my son..
The Great and Mighty SnowDuck
Snow Duck has a reputation beyond reputeSnow Duck has a reputation beyond reputeSnow Duck has a reputation beyond reputeSnow Duck has a reputation beyond reputeSnow Duck has a reputation beyond reputeSnow Duck has a reputation beyond reputeSnow Duck has a reputation beyond reputeSnow Duck has a reputation beyond reputeSnow Duck has a reputation beyond reputeSnow Duck has a reputation beyond reputeSnow Duck has a reputation beyond repute
Garage
Default
I would for sure clean the carbs and jets if it has been sitting for over a year also!
__________________
  #7
Old 01-06-2016, 11:13 AM
sno*jet sno*jet is online now
Currently: Not set.
sno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond repute
Default
Quote:
probably. could also be the throttle cables need adjusting. if theyre out of whack the slide(s) could be hanging too high above the idle screws. make sure theyre both in perfect synch, and there should be a tiny bit of movement in your throttle before they start to pull the slides up so you know your sitting on the idle screws.
The Following User Says Thank You to sno*jet For This Useful Post:
preclatton (01-06-2016)
  #8
Old 01-16-2016, 06:11 AM
TKrug21 TKrug21 is offline
Currently: Not set.
Basic Member
TKrug21 is an unknown quantity at this point
Default Clean those carbs!
Carbs can be very weird, do lots of strange things when they are gummed up. The problem is, sometimes you can go all through them and they "look" just fine, but can still have internal passages plugged.
There has been times I have had to do mine 3 times before they worked right.
While your at it, you also check all the other related things, like choke and throttle cables, slides moving freely, all screws set the same on each carb, etc.
I have had choke cables stick open, making the engine run high, twice.
Good luck.
  #9
Old 02-05-2016, 06:02 PM
sdsmith sdsmith is offline
Currently: Not set.
Basic Member
sdsmith is an unknown quantity at this point
Default
there is another screw to adjust I just cannot exactly remember what it is called. Mine did the same thing and somewhere I found info on what to adjust. I apologize for replying and not remembering but maybe someone else will help us out.
I think it has something to do with air.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 2002 800 rmk high idle Thread Starter — 800rmkedge Forum — Polaris Replies — 0 Last Post — 03-04-2013 09:48 PM
Thread — High idle on 2001 700 RMK Thread Starter — steepndeeper Forum — Polaris: GEN 2 Replies — 8 Last Post — 02-28-2013 10:46 PM
Thread — High idle on 2007 rmk Thread Starter — Repsol83 Forum — Polaris: IQ Replies — 6 Last Post — 12-30-2011 09:10 AM
Thread — high idle 01 800 rmk Thread Starter — jer Forum — Polaris: GEN 2 Replies — 2 Last Post — 11-08-2011 09:26 PM
Thread — 02 RMK 800-high idle problems Thread Starter — frozen north Forum — Polaris Replies — 23 Last Post — 09-30-2008 06:20 PM
no new posts
