Upgrade to Premium
Polaris: Pro-Ride 2010 and up, all models in the Pro-Ride chassis
Reply
  #1
Old 05-12-2019, 02:07 AM
xtremejcx xtremejcx is offline
Currently: Not set.
Basic Member
xtremejcx is an unknown quantity at this point
Default Manual/tips for changing pistons on 13’ Pro-RMK
Hi
Is there anyone out there that would be willing to share the workshop manual on changing pistons on a Pro? Or is there any manuals/books I can buy? Other tips would be greatly appriciated! Sled has 4100 miles on stock pistons!0
Rate this post: Yes | No
  #2
Old 05-12-2019, 06:54 AM
TRS's Avatar
TRS TRS is online now
Currently: 2019-2020 winter on the way
TRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond repute
Default
Contact your dealer. He may loan or sell you one.
  #3
Old 05-12-2019, 09:30 PM
sledhed's Avatar
sledhed sledhed is offline
Currently: Done riding my new-to-me 17 Axys 162 CamoX 2.7 LE Titanium Orange for the season...
sledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond repute
Default
You can buy the electronic version fairly cheap if I recall correctly. If not PM me, I might have an electronic one I would have to look around, maybe for 2012, not sure, don't have a Pro-ride any more (recently moved to an Axys).
You are definitely due for maintenance top end... well, depending on type of miles I suppose but I would rather err on the side of safety. Had a catastrophic failure on a Skidoo 800 at about 1500 miles and the motor was basically junk, that can get expensive, so throw a set of Axys pistons in there. You will get lots of opinions on whose pistons to use... I tend to go OEM, Indy Dan recommends that too. Make sure you inspect (or have someone inspect) the cylinder skirts too, less common in the newer Pros but they can crack and even fail.
__________________
Snowest forums member since December 19, 2001...
Member:Missoula SnowgoersMontana Snowmobile Association
  #4
Old 05-13-2019, 12:17 AM
Currently: Not set.
Basic Member
Default
Actually in Norway (where I’m from), many sleds go this far without opening the engine, some even go 5000 miles with nothing done. Anyways, I did a compression test and it showed 100psi on both cylinders so I’m probably going to do it. Already asked dealer and they wouldn’t lend me the manual. Been looking for it online aswell but with no luck.
  #5
Old 05-13-2019, 12:26 AM
AkRider217 AkRider217 is offline
Currently: Already waiting for winter again...
Basic Member
AkRider217 is an unknown quantity at this point
Default
Just bought a used sled for pretty cheap knowing it had only 95psi, what's surprising though is the sled only has 2080 miles. Kind of funny you have more than twice as many miles and still have better compression. I don't know how my sled has this bad of compression. Doing a rebuild of course.
  #6
Old 05-13-2019, 06:07 AM
Big10inch Big10inch is offline
Currently: Still Riding...
Basic Member
Big10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond repute
Default
When a sled goes 5000 miles on pistons, they are commonly know as "trail miles"...LOL Not an anomoly, happens all the time.
  #7
Old 05-13-2019, 06:46 AM
Currently: Not set.
Basic Member
Default
Actually no, mine has 4100 off trail miles. A lot of 5000 mile sleds are pro’s used for what they should be used for. Dealers just up the oil pump and they are good to go.
  #8
Old 05-13-2019, 09:21 AM
TRS's Avatar
Default
https://servicemanualwarehouse.com/p...ervice-manual/
  #9
Old 05-13-2019, 09:54 AM
Currently: Not set.
Basic Member
Default
I’ve had that manual for some time now, just now realised that piston change is actually partly covered in it.
  #10
Old 05-13-2019, 11:32 AM
TRS's Avatar
  #11
Old 05-13-2019, 12:07 PM
sledhed's Avatar
Click Here to Register
  #12
Old 05-13-2019, 04:23 PM
TRS's Avatar
  #13
Old 05-13-2019, 04:39 PM
sledhed's Avatar
  #14
Old 05-13-2019, 07:22 PM
TRS's Avatar
The Following User Says Thank You to TRS For This Useful Post:
sledhed (05-14-2019)
  #15
Old 05-13-2019, 10:39 PM
Currently: Not set.
Basic Member
The Following User Says Thank You to xtremejcx For This Useful Post:
TRS (05-14-2019)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Anyone have some Tips/tricks for changing ECU Thread Starter — uSoTiNy Forum — Polaris: IQ Replies — 3 Last Post — 03-23-2017 07:19 AM
Thread — Any tips for changing a starter on a mc-xpress nytro? Thread Starter — snowmanx Forum — Yamaha: Boosted Sleds (Turbo or Supercharged) Replies — 9 Last Post — 01-23-2017 10:28 PM
Thread — Any Track Changing Tips? Thread Starter — cpa Forum — Arctic Cat: Proclimb M Replies — 9 Last Post — 12-14-2012 11:42 PM
Thread — Changing tires on mirage trailer any tips? Thread Starter — machinest660 Forum — Trucks and Trailers Replies — 3 Last Post — 04-27-2012 11:15 PM
Thread — tips on changing out reeds Thread Starter — chris79 Forum — Performance/Modified Replies — 6 Last Post — 05-28-2008 04:14 AM
no new posts
