Really...nobody??
This must be some kind of gimmick then i assume:face-icon-small-con
mine is being balanced. will post up the gram'ige when i find out. i think its a cheap thing to do and should aid in belt life, clutch parts life and crank life possably as well.
I have not gotten mine back yet either, but I sent mine to perks spin balance. He also has an external crank balancing kit that I ordered too. People on sno west said they reccomended him and that its a very good thing to do to make crank bearings last longer, gain some power, and also make the vibration leave your hands. The guy at Perks swears that on his 2010 backcountry 800, which is the same sled as mine with the crank kit and the clutch balancing he gain up to 13 mph. So I guess we'll see about all of that. I sure hope all of its true! I should be getting it all back on the sled this weekend if it comes in the mail tomorrow!:face-icon-small-ton
Definitely post your findings on this. I am not an engine builder or anything and what he said made some sense to me, but I immediately had a red flag pop up when I heard the mph gains. He told me 20 mph on the phone. I'm not saying it isn't true, I just find it hard to believe. Also referring to other SWers saying that the engine kit thingy is a good idea, There were a lot of mixed feelings about that in the threads. I think the clutch balancing was mostly agreed upon to be a good idea, but the bolt-on engine balance kit had a lot of discussion concerning it. The original poster in this thread should doo a forum search and decide after reading a little more. I didn't intend to bash anyone with this post, but I am very skeptical of "too good to be true" gains.
I definitely did do a search. Found a thread by "indydan" describing in detail
the who, what, why and how of clutch balancing. I was unable to actually determine by the various post's if anybody had a before/after report?? I was merely looking for someone who had balanced their clutch and could report on the benefits or lack of...
:face-icon-small-ton I have a 2010 Ski-Doo 800cc and after the balance work on the clutch and most important on the engine balance and different designs in the mag. rotor and sled break in. It went from 84 MPH to 103 MPH (June 30th 2011 in poor snow conditions at 9500 ft.). It has no clutching work done, it has electric start (10 to 15 lbs.), it has the big exhaust tank, basically only the balance work. My son who weighs 170 lbs. has raced several 2011 etecs, 2011 Polaris Pros., M1000 & M800 Arctic Cats and several other sleds and even a couple of Ski-Doos with turbos and has beaten everyone on the flats at 9500ft.
:face-icon-small-ton I'm just running it at 1400 rpm under a 1 1/2 horse motor for about 20 seconds to about 1 minute to get readings so I just put some dropps of oil down in the cylinder walls.
When I run it in the sled it's about 2550 rpm and it's being ran under the power of the sled.
skidoo must have found something with balance. on my 2012x the crankshaft has an index mark on it that matches mark on the clutch.....
Not trying to cause trouble, but I would think it would be wise to spray a fuel/oil mixture in the intake as to lube the connecting rod bearings. It shouldn't bother the balancing. A minute is a long time if the bearings are dry or just have oil laying in the bottom.
