I bought a used power comander V at haydays, is there any way to tell what map is loaded on it? its for my o9 assault that is running the original reflash.
Your best bet is to either reload the map with a known one or check the map against what would be correct for your version of the ECM flash. Every ECM flash needs a slightly different PC5 map to work correctly. Further, lots of guys "customized" their maps for their own sleds and mods so what you have may not be what it seems unless the previous owner was careful about documenting what he was doing. Better safe than sorry....
Where do you ride? I run the SLP map, its very good. I have run both, DT is too rich for me. I ride in the mountains mainly. If you're running at home (low elev.) you may want to turn on a feature in the pcv called "accel pump" . They recommend it and its in the notes that come up on the screen with the map.
