I am installing a MCX 180 kit on my 2008 Nytro. The instructions say to use the stock mounting bolts and rubber mounts when installing the steel bracket to the turbo. Of course I threw the stock muffler away along time ago, but dug through some boxes to find some parts. Are these the correct mounts and does this look right? Everything seems to fit but it sure seems like the turbo will flop around alot. I am going with a tunnel dump so I won't have the muffer to help keep everything solid.
Also, I am getting ready to cut the stock header. There are two pictures in manual. One shows a collector tube being cut off as well which doesn't make sense. Is this required?
I am sure this will just be the start of the questions.
Thanks.
Thanks.
