WORTH CHECKING: Belt Deflection Adjuster on '2018 Secondary clutches
Mr. Pump Gas
218
26
We have 4 - 2018 AXYS. 155, 2.6. All have had their belt deflection adjusters back out?
3 blown belts between 2 of the sleds.
Don't recall have any of these issues on our '16's?
Zrider
726
305
Sparks, NV
Is the flexloc nut getting loose and then letting the screw adjuster back out? Have never had this problem with the Team secondary. You might want to contact them and ask what is going on. Maybe they changed something on the 18's. Please keep us advised.
I
1,337
Happened first ride on my 18 and burned the belt before I caught it. I ran it back in tight and it backed out again the next ride so I loctited it. Polaris warrantied it, new set screw/nut and belt. Have not ridden it since.
mountainhorse
18,606
11,814
West Coast
www.laketahoeconcours.com
Same screw and nut all the way back to the Dragons.
But could be a bad batch of nuts??
Probably just not well snugged down at the factory.
BUT, don't over tighten it or you will find yourself breaking the screw.
Adjust it, then snug down the nut to 110 in-lbs (12 Nm) [just shy of 10 ft lbs]
Use some blue loctite under the nut.
DO NOT OVER-TORQUE
Sounds like assembly line issues to me..
mountainhorse
18,606
11,814
West Coast
Deflection method
From Polaris Service manual:
AXYS BELT DEFLECTION INSPECTION /
ADJUSTMENT
Measure belt deflection with both clutches at rest and in
their full neutral position.
Place a straight edge {1} on the belt and apply downward
pressure while measuring at point {2}. This measurement
should be 1 1/4 inches (3.2 cm).
To adjust belt deflection:
1. Loosen the 11 mm jam nut on the belt width adjuster
screw.
2. Using a 3 mm Allen wrench, turn the set screw inward
(clockwise) to increase the distance between the
sheaves (increase deflection) or outward (counterclockwise)
to decrease the distance (decrease
deflection).
3. Tighten the jam nut while holding the set screw
stationary.
kiliki
13,213
2,398
Nampa, Idaho
when cat went to team clutches in 16 we have seen it a few times as it has about the same set up. Just need to be very careful as the tight and broken are just a very small torque ratio apart.:face-icon-small-blu
C
Feb 8, 2008
241
60
My 174 was having the adjuster screw back out about two or three times each day last year.
I geared it down to get rid of the clutch heat and have not had the problem since.
kidder17
111
65
Saskatchewan
Happened on my 2018 163” as well on my first ride. Started as a light squeal and progressed into a loud squeal and then to the point that the sled would creep and move forward on its own before I looked to adjust it and found it backed off to the point of almost falling out
Dazzler
267
145
Cochrane Ab
Same here, had two 2018,s out last weekend, a 163 and a 174, both had the belt tension screw back out.
Sheetmetalfab
7,911
6,672
Ha my brothers 18 came loose today.
Caught it at 1/16” out. (Squeel)
Sent from my iPhone using Tapatalk Pro
Wheel House Motorsports
29,933
5,968
SW MT
Had it happen to mine too. Seems like I have to run the nut WAY tighter then the speced 10 Ft lbs or it will come loose with ease.
Almost like the clutch threads are slightly loose or something.
