just went through the same thing on my 09 turbo m8,hated hated hated the stock bars,and ugly controls... and the adjustable post had way too much slop in it...comming from a 07 rev with tight steering i hated it! and all i have ever ridden were race sled with 440 bar setups and the m8 stock steering had to go...biggest beef with the sled...
my setup
- 09 600 sno pro 600 bars (steel bars so the warmers do work!!!)
- aluminum throttle block,sno pro 600 kill switch,mxzx 440 dimmer switch, polaris assult reverse switch, and 3 position switch in console for hand/thumb warmers and 07 sno pro bar pad
- 10 inch black riser
- wildchild chrome-moly re-enforced steering post with T Top
- BDX Steering support (must have!)
this setup makes the sled feel like the 440 sno pros without cutting up your hood...and i could put the bars alot more forward...and still have 1" higher than stock height with adj post up high...
although the 440's steering post is straigher and has a more natural feel when turning,and the turning forces dosent work against itself like the m series sleds....this setup works good...
i would have went with the 440 sp setup but the turbos parts take up the room...
