Upgrade to Premium
Arctic Cat: Powder Special and older 2000 and older, all models in the Powder Special chassis and older chassis models
Reply
  #1
Old 04-09-2014, 09:19 PM
exocticsrnw exocticsrnw is offline
Currently: Not set.
Basic Member
exocticsrnw is an unknown quantity at this point
Default 96 zrt600 rear skid swap ?'s
hello everyone im new to the forum I have a few questions I have a 96 zrt600 that I want to long track to a 159 im on a 136 now I cant find any rails or rail ext that are long enough for this so I was wondering if there is another skid I could use like the ett or something else that would give me a little more travel I can get custom rails made at iceage but id like to upgrade all the rear suspension at once just don't want to spend 3 grand doing it also if I could and raise the rear of the sled 3" I want to run the 159 and I don't want to get rid of my sled I just don't have enough track with all the other mods done I like it any help with this would be great
Rate this post: Yes | No
  #2
Old 04-09-2014, 11:06 PM
Reeb's Avatar
Reeb Reeb is offline
Currently: Restoring my old race sleds....
Reeb has a reputation beyond reputeReeb has a reputation beyond reputeReeb has a reputation beyond reputeReeb has a reputation beyond reputeReeb has a reputation beyond reputeReeb has a reputation beyond reputeReeb has a reputation beyond reputeReeb has a reputation beyond reputeReeb has a reputation beyond reputeReeb has a reputation beyond reputeReeb has a reputation beyond repute
Garage
Default
Buy a 1M skid for it. It'll be a direct bolt-on.
__________________
NMFH....an enigma wrapped in a riddle.....
Lisa Simpson: Nothing is as fun as snowmobiling looks
Bender: But I can't live without technology.....and snowmobiles.
'94 ZR 700 twin turbo mach z triple with a holly double
pumper and belt drive.......on NAWWWZ!!!
Together We Ride T+D 12-24-07
  #3
Old 04-09-2014, 11:30 PM
Bearcat Bearcat is offline
Currently: Not set.
Basic Member
Bearcat has a reputation beyond reputeBearcat has a reputation beyond reputeBearcat has a reputation beyond reputeBearcat has a reputation beyond reputeBearcat has a reputation beyond reputeBearcat has a reputation beyond reputeBearcat has a reputation beyond reputeBearcat has a reputation beyond reputeBearcat has a reputation beyond reputeBearcat has a reputation beyond reputeBearcat has a reputation beyond repute
Default
If you like to modify a bit, M-series float skid will work too. You need to add 1cm thick aluminum to narrow tunnel at front mount as the M-series front arm is narrower than ZR style. Rear arm should bolt on, but you need move the rear mounts to fit M-series skid location.
Here's a pic of my rear mounts I made By my self. I used the same thick aluminum plate at front to narrow the tunnel. Just bolted over the stock holes and drilled holes.
I removed the stock running boards and bought aftermarket ones. I installed the boards higher at back to increase space between boards and snow. I bought M-series rolls and gussets so I took the measures from M-series to fit all together.
  #4
Old 04-10-2014, 04:42 PM
Currently: Not set.
Basic Member
Default
so heres what I did im thinking it is a wise move I found a 159" skid complete out from under a 2004 vertical edge rmk800 I got it for 330 with shipping and a buddy of mine has upgraded shocks I can get for it this whould be close to bolt in I know I need spacers for the upper mounts but other then that its already set the way I want and its got 17" of travel now I just have to get it all together need to strip it and also do some powder coating and paint work I thank you for your input i will be putting up some pics as i build it should be a pretty wicked mod sled when done
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 96 ZRT600 Miss Fire Thread Starter — Ged4th Forum — Arctic Cat: Powder Special and older Replies — 1 Last Post — 01-24-2011 08:39 AM
Thread — parts fitment 94 zr700 96 zrt600 front suspension Thread Starter — robyracer Forum — Arctic Cat: Powder Special and older Replies — 3 Last Post — 01-07-2011 06:53 PM
Thread — polaris 96 141 rear skid Thread Starter — pauly-doo Forum — Suspension/Shocks (Swapmeet) Replies — 1 Last Post — 11-28-2009 03:31 PM
Thread — 95-96 storm rear skid Thread Starter — pauly-doo Forum — Polaris: GEN 1 and older Replies — 4 Last Post — 11-27-2009 01:32 PM
Thread — polaris 96 141 rear skid Thread Starter — pauly-doo Forum — Suspension/Shocks (Swapmeet) Replies — 7 Last Post — 02-08-2009 10:29 PM
no new posts
