2005 iqr Mountain mod 2003 800ves rebuild need help
Hi so I just bought a 2005 iqr mountain modded sled and wanted to learn how to work on sleds and am going to need help if anyone is interested.
Im going to put a pic of the ad so u can see what i have.
I tore into the sled and the motor was trashed bottom and top end so im having it rebuilt right now.
The motor is a 2003 800ves and its about 1,000 bucks for the whole rebuild once complete which includes new bearings on crank and new connecting rod and either nickasil or sleeves and bore on top.
I noticed the whole bottom end of the sled was flooded with oil so i think the oil injector is bad but i really would rather it did work so im going to try and fix it and mix the gas while testing. Im putting a pic of the injector the frame of the chassis was cut to make room and i think the cable draw bracket was rubbing and getting stuck open so im going to change the frame up a bit
Also i dont know anything about how to setup the clutch once i get the motor back in or what to do with the carbs once i have a fresh motor.
Another issue the motor had is the previous rebuild someone pinched the o-ring on the jug and the piston was blowing by into the coolant and the ports where the coolant flows is nasty black and has metal in it from the motor how do u clean all that metal out or do the tiny particles not really matter and flushing it good enough?
Im sure im forgetting alot and i have a million questions if anyone is interested in helping me i would appreciate it!
Note: file sizing is weird here and i could only fit the one picture
