Drive chain broke TB2015
L
Oct 13, 2012
33
14
8
Brand new 2015 kit
Maybe 4 to 6 hrs on a new kit,chain broke bunched up inside case ,broke the case,all i can think is that the chain master link wasn’t installed properly?
dirtrebel
429
277
Bozeman, MT
could be, most likely but did you check the tension after every ride at a minimum? If it gets loose then starts pounding every time you go on the gas off the gas it really puts a beating on the chain. also if it was too tight that's bad too. I noticed I overtightened mine because it has a loose spot and a tight spot. if you tension it at the loose spot then it will be too tight at the tight spot, those shafts dont run true ya know?
M
Jan 14, 2004
3,079
1,390
When there is/was a tension problem it will often take out the plastic idler sprocket. How does that look?
M5
U
Sep 12, 2010
456
150
Check your bearings, too. If a bearing goes, the chain tension and alignment goes and all hell breaks loose.
Where are the photos?
K
kell8071
216
48
Vashon, WA
This isn't only attributed to shaft run out. Chains have tight spots and it is always recommended by the OEMs to check your tension/slack in multiple spots. This is very noticeable on dirtbikes if you monitor for it.
However at under 10 hrs on a new kit I am guessing the master link came apart. Any info on where the chain broke?
P
PalousePoo
173
Farmington, Wash.
SO the masterlink was apart? If so, then it obviously wasn't installed properly or maybe the clip was left off? Did you find a clip? Very odd for a chain to just break a link. Or did you hit a rock sidehilling, break the cover, and then damage the chain?
