G
What is the best way to remove the quick couple drive shaft piece from the chain case? I want to remove it to install a 21/22 solid drive axle. It is press fit into the bearing in the chain case. Thanks
I am planning to do this soon, is it obvious which way to pop it out? is it pressed in from the outside or from the inside?What is the best way to remove the quick couple drive shaft piece from the chain case? I want to remove it to install a 21/22 solid drive axle. It is press fit into the bearing in the chain case. Thanks
