L
Chain case too,is this common?
Maybe 4 to 6 hrs on a new kit,chain broke bunched up inside case ,broke the case,all i can think is that the chain master link wasn’t installed properly?
could be, most likely but did you check the tension after every ride at a minimum? If it gets loose then starts pounding every time you go on the gas off the gas it really puts a beating on the chain. also if it was too tight that's bad too. I noticed I overtightened mine because it has a loose spot and a tight spot. if you tension it at the loose spot then it will be too tight at the tight spot, those shafts dont run true ya know?
