Two unrelated questions--
1. Any suggestions on loosening the clicker pivot bolts? I broke two Torx wrenches. Luck day, however-- got the piece out of the bolt head both times!
2. I want to screw a GPS mount to the area of the bottom right corner of the "indicator cover" (the plastic cover part that holds the tach/speedo etc gauge) and the "console" (the plastic cover part that runs from the tank forward). Does any one know if there are any lines, wires, etc that would be a problem if I drilled just ahead and to the right of the steering column? I plan to stay to the left and behind the air intake gallery.
Thanks!
Thanks!
