Upgrade to Premium
Polaris: TURBO Turbo discussion for Polaris aftermarket turbo sleds
Reply
  #1
Old 09-12-2017, 12:15 PM
Jreng87 Jreng87 is online now
Currently: Not set.
Basic Member
Jreng87 has a reputation beyond reputeJreng87 has a reputation beyond reputeJreng87 has a reputation beyond reputeJreng87 has a reputation beyond reputeJreng87 has a reputation beyond reputeJreng87 has a reputation beyond reputeJreng87 has a reputation beyond reputeJreng87 has a reputation beyond reputeJreng87 has a reputation beyond reputeJreng87 has a reputation beyond reputeJreng87 has a reputation beyond repute
Default 10lbs, stock quick drive, and 3"... who's running?
Anyone running a 3" boosted on the stock quick drive system? I'm looking to convert the 2.6 to a 280 or x3 track and will be set to run about 10lbs. Can the stock QD handle that well or is the TKI kit a "must" at that point? If the TKI is a must then that would probably scrap the plans to swap tracks at an additional $700...
Rate this post: Yes | No
  #2
Old 09-12-2017, 01:58 PM
Davajn Davajn is online now
Currently: Braaaaap
Davajn has a reputation beyond reputeDavajn has a reputation beyond reputeDavajn has a reputation beyond reputeDavajn has a reputation beyond reputeDavajn has a reputation beyond reputeDavajn has a reputation beyond reputeDavajn has a reputation beyond reputeDavajn has a reputation beyond reputeDavajn has a reputation beyond reputeDavajn has a reputation beyond reputeDavajn has a reputation beyond repute
Default
The stock QD takes quite a bit of punch to be honest. Its really good on the axys. The only downfall is that you cant change gearing like the tki beltdrive can.
But if you are going a 2.8 or 3" track then you need to change drivers. And then its avid no-slip and anti stab axle thats the way to go. And that costs quite a bit...
Dont go with the 280.... I've tried serie 6, 7, 280 and CE X3. Serie 6 aint a bad track to be honest. Pops up really good on snow. X3 gets you alot more forward thrust but abit less popup.
The durability of the X3 is really amazing tho!!! 280's durability is like serie 6 or worse. Lighter track = less rubber = bad durability.
If i were you. Boost it and run it with stock track/QD and just add some more cash to the fuel account. More miles on the sled is always the best value
2 out of 2 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to Davajn For This Useful Post:
Jreng87 (09-12-2017)
  #3
Old 09-12-2017, 03:28 PM
aksledjunkie's Avatar
aksledjunkie aksledjunkie is offline
Currently: Payin' the dough to play in the snow
aksledjunkie has disabled reputation
Default
Kurts Off-Road offers a gear down kit for the AXYS QD. IF you are interested in going that route.
__________________
Born & Bred to Rip & Shred
'17 AXYS 800 155" Silber Turbo
@aksledjunkie
  #4
Old 09-13-2017, 08:34 AM
tdbaugha tdbaugha is online now
Currently: Not set.
tdbaugha has a reputation beyond reputetdbaugha has a reputation beyond reputetdbaugha has a reputation beyond reputetdbaugha has a reputation beyond reputetdbaugha has a reputation beyond reputetdbaugha has a reputation beyond reputetdbaugha has a reputation beyond reputetdbaugha has a reputation beyond reputetdbaugha has a reputation beyond reputetdbaugha has a reputation beyond reputetdbaugha has a reputation beyond repute
Default
Wouldnt change the stock Quickdrive. I've seen better durability with it compared to TKI.
We have 3 sleds running 9+ psi with stock QD and Pro RMK belt. I don't even bring a spare belt anymore. That's how confident I am with it.
The Following 3 Users Say Thank You to tdbaugha For This Useful Post:
Jreng87 (09-13-2017), mtncat1 (09-14-2017), wellfed777 (09-24-2017)
  #5
Old 09-13-2017, 08:45 AM
B&M Fabrications's Avatar
B&M Fabrications B&M Fabrications is offline
Currently: Working
SnoWest Sponsor
B&M Fabrications has a reputation beyond reputeB&M Fabrications has a reputation beyond reputeB&M Fabrications has a reputation beyond reputeB&M Fabrications has a reputation beyond reputeB&M Fabrications has a reputation beyond reputeB&M Fabrications has a reputation beyond reputeB&M Fabrications has a reputation beyond reputeB&M Fabrications has a reputation beyond reputeB&M Fabrications has a reputation beyond reputeB&M Fabrications has a reputation beyond reputeB&M Fabrications has a reputation beyond repute
Default
It's not a necessity really but you do lose a little control and adjustability without swapping to the TKI. Also an FYI if you are breaking TKI belts, something else is wrong whether it's a bad bearing or running the belt too tight. When the system is cold it should feel borderline loose. After a stock QD belt is broken in they will look slightly loose too.
Sent from my SM-G928V using Tapatalk
__________________
Visit us online at www.Bmfabrications.com!
Shop: 612-202-9245
E-Mail: Info@bmfabrications.com
Social Media Accounts
facebook.com/burlybmfab
Instagram: @burlybmfab
Twitter: @burlybmfab
  #6
Old 09-13-2017, 11:24 AM
Default
Quote:
1400 boosted miles last year and still on the original QD belt. ^^^^ He's not wrong in his confidence.
__________________
@aksledjunkie
  #7
Old 09-13-2017, 04:19 PM
Currently: Not set.
Basic Member
Default
Quote:
Ya I ran the 2.6 turbo'd last season at 7lbs but more curious to 3" and more boost with the QD
  #8
Old 09-13-2017, 05:17 PM
Jaynelson Jaynelson is online now
Currently: Not set.
Jaynelson has a reputation beyond reputeJaynelson has a reputation beyond reputeJaynelson has a reputation beyond reputeJaynelson has a reputation beyond reputeJaynelson has a reputation beyond reputeJaynelson has a reputation beyond reputeJaynelson has a reputation beyond reputeJaynelson has a reputation beyond reputeJaynelson has a reputation beyond reputeJaynelson has a reputation beyond reputeJaynelson has a reputation beyond repute
Default
Seen it done a few times for sure....Axys and Pro. Fire and Ice belt deflection kit was a super simple little upgrade on the Pro for that application. Not sure if they have 1 for Axys....worth looking in to for the $$.
  #9
Old 09-14-2017, 10:41 AM
AKFULLTHROTTLE's Avatar
AKFULLTHROTTLE AKFULLTHROTTLE is offline
Currently: Loving my Silber Turbo!
AKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond repute
Default
Ran my 13 Pro with belt at 12psi with a 162 3" CE. Zero issues, never carried a spare.
__________________
Full Throttle Customs
Alaska Silber Turbos Dealer
http://www.silberturbos.com/
  #10
Old 09-17-2017, 12:17 AM
niner's Avatar
niner niner is online now
Currently: loving my MTNTK turbo
niner has a reputation beyond reputeniner has a reputation beyond reputeniner has a reputation beyond reputeniner has a reputation beyond reputeniner has a reputation beyond reputeniner has a reputation beyond reputeniner has a reputation beyond reputeniner has a reputation beyond reputeniner has a reputation beyond reputeniner has a reputation beyond reputeniner has a reputation beyond repute
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 3" track on stock belt drive??? Thread Starter — edgey Forum — Polaris: AXYS Replies — 24 Last Post — 08-09-2016 02:28 PM
Thread — Looking for 13-15 stock quick drive pulleys Thread Starter — ullose272 Forum — Clutch/Drive Train/Belt (Swapmeet) Replies — 2 Last Post — 03-25-2016 01:16 PM
Thread — 3" track with stock belt drive? Thread Starter — Dirty Steve Forum — Polaris: AXYS Replies — 12 Last Post — 11-19-2015 04:09 AM
Thread — Quick drive to C3 belt drive Thread Starter — Ephratafarmer Forum — Polaris: Pro-Ride Replies — 9 Last Post — 01-15-2013 11:28 AM
Thread — After Quick Drive Belt "Break In" are they as fragile Thread Starter — Cascade Addiction Forum — Polaris: Pro-Ride Replies — 3 Last Post — 11-29-2012 10:32 AM
