After a few different setups and stages from slp I have gone back to a stock ported cylinder from Indydan. I sold all my slp stuff and just got the sled out for the first rip this morning. Setup follows.
2012 800 switchback assault
Fresh Lon Rod Torque Master3 w/HG7 cylinder finish and matching pistons
vforce3r reeds/no controller on it yet.
balanced primary and team tied. otherwise stock clutching components.
I followed the break in instructions for heat cycling and took it out for a ride this morning. I was just cruising taking it easy around the lake and then i stabbed it a couple times. I was more worried about engine temp then rpm so i had that screen up. I noticed it reved fast and I thought something was not right as I was getting a bog. It was reving really fast when hitting the throttle Flipped to the rpm mode and noticed with 10-66 weights it was instantly reving to8450-8500!!! Yes a little over rev but very excited that it is doing this with only about 25 miles on the top end! I have a feeling this engine is going to be a beast!! I will be putting in heavier weights and reporting back I'm guessing I should be in the 70-72 gram range to get it dialed in and running. I was putting it back to stock to sll the machine but this has made me want to keep it longer now
