How much more did it weigh? Was the fst motor a pretty tight squeeze?
Just under 460 dry with a lot of machining that I would never do if it were my personal sled.
The fit wasn't too bad, but needed to CNC motor mounts, intake runners, remake 02 housing, clock turbo a little differently, different routing for piping, move steering to right side, and moved a lot of little things around.. water to oil cooler, the 'new' dash uses different CAN inputs, etc. etc. etc...
The main issue we had was getting the dry sump oil system working and oil bottle exit at the bottom of the head.. went through 7 ish rod bearings/cranks, but that should be avoidable..
The sled is really fun though when cranked up (note the massive Tial Q) haha. If you want to read up on most of the things that needed to be done you can check out the link below.. It's not really up to date, but most of the stuff is there.. The main thing to ignore is the aluminum oil bottle.. don't use one of those. lol.
http://www.mtukrc.org/download/mtu/mtu_ic_design_paper_2011.pdf
The 900 Ranger/rzr engine in the pro chassis was a lot tighter fit, but went a lot smoother since it is wet sump and we didn't have reliability issues.. but it is kind of a turd and the calibration isn't perfect. (not that the fst is)
Both sleds have standalone ECU's and run 'flex fuel' E0 to E85.
We also have a worthless electric rush!
