2007 M8 SLP Single Pipe
Richey
20
18
Utah
One of my friends is running a 2007 M8 with and SLP single, SLP air intake, and reeds. He is not running a fuel controller. He says it runs pretty good but the clutting is off a little. What are you guys running on your setups. I believe that he is running stock springs in the primary and secondary. He also has the stock helix. He just changed his weights to the 71 Gram MTX weights that SLP recomended. He wants to gain 150 RPM, he is only running at 7950 RPM currently.
G
GONRIDIN
Guest
Running the same with 71 MTX's with 2 grams in the tip for 6-9000ft. He may need to take a gram out as I bet he rides a bit higher than I do. This one pulls the hardest at about 8050 to 8100. This set up realy works well.
Richey
20
18
Utah
Sorry forgot to tell you that he is running from 8000 to 10000 feet elevation.
