J
First off. My title should read MPI turbo on viper. Issues. It is issue with oil spillage
Hithere. I am looking for a solution. I put a 180MPI turbo on my Viper. When I'm doing donuts in the meadows if I fall off and the sled slightly tips on its side it leaks oil all over the clutching and belts. You can guess what that leads to
Once the oil is on my clutch/ belts it takes pretty much 3 hours to burn off. It squeaks. Squeals. Barely moves at first. This has happened 2 weeks in a row, since I've had the sled basically.
Basically I bought a mountain sled but in reality I can only use it as a trail sled as it can't be on its side. And by on its side, I mean barely on its side, kinda leaning on the powder.
I have talked to Yamaha and they have let me know MPI knows of this issue. Also the rollover valve was not recommended from Yamaha as they have a high failure rate. Yamaha has been very good about it. Thumbs up for that. I'm just trying to get some info to hopefully solve my issue so I can start fully enjoying my sled. Thanks for any advice.
