This is a parts list and a step by step of how to convert a 1M to use the '08+ float rear suspension.
Originally posted by 76FOMOCO
1, you will need all of the following parts.
2706-456 Bracket, Suspension Mounting - Right – Rear
2706-457 Bracket, Suspension Mounting - Left – Rear
Alternatively to these brackets, you can use any other bracket that will drop the suspension low enough for the track to clear.
0648-066 Shaft, Stub (use this to make spacer)
3604-396 Rail, Formed (x2)
4639-994 Float conversion
The conversion was done for about 750.00 and ended up with just short of a new skid with the pump.
2, this can be done using some of the old skid parts.
3, put the skid together with the front shock and cross bar from the stock 1M skid.
4, you will need longer bolts for the front mount about ¾” longer and will need to make your own spacer of a ½” (M is 16” wide and the 1M is 17” wide on the tunnel)
If not using the M-series brackets:
5, install whatever other drop brackets you chose, and install the suspension
If using M-series brackets:
5, you will need to drill out the old rear skid brackets and rivet in the new ones at 31.25” back center to center of the lowest hole on the rear and the front stock hole.
6, install the skid and adjust as needed
