The 910 IS an impressive engine, but it will be no where near 190 hp at altitude.
The 600 on 13 - 14 lbs should get you into the 210 hp range easily...BUT... That engine will not give you the best bottom end performance... If you are an advanced rider and already very comfortable in the trees in tight situations... you will adapt fast.
Clutching and riding technique will play a big role in the 600 CFi turbo's abilty to boondock well.
Why not the 700Cfi-4 with turbo.
Since you already have a 155 RMK....
I agree with Angermanagement and suggest the 150" Camoplast Ch Ext 2.5" lug x 15 wide with a T-600/700 to round out your stable.... Unless you really want a climber... The 150 will give you great deep snow performance and the mobility to throw the sled around well.
The 3" pitch of the 150" Ch Ext give you the ability to run
the new style Avid drivers in a 7 tooth for more tunnel clearance.. the new drivers really do work more smoothly and engage the track better than the previous style.
Just my 2 cents.
