C
Polaris 800 RZR - INTERCOOLED TURBO KIT - BRAND NEW
This is about the most efficient bolt-on power booster available for your RZR. A customer returned the kit and we can't sell it as new. So this is a great opportunity to save some money on a turbo kit. Please note the the pics are of the new kit, but all the parts are the same. We will have actual pics available soon. Call us for details on the kit. $2895.00
THE RZR SYSTEM IS FUEL INJECTED AND IS A BLOW THOUGH SYSTEM. IT WILL PRODUCE A 50 PERCENT OR MORE INCREASE IN HORSEPOWER DEPENDING ON HOW
MUCH BOOST YOU RUN. WE SUGGEST THAT YOU RUN RACING FUEL AT 6 LBS. OF BOOST AS A CONSERVATIVE HORSEPOWER INCREASE. NOTE: IF LARGER TIRES ARE USED YOU WILL NEED TO PUT SPACERS ON THE WHEELS.
The Polaris RZR Intercooled Turbo Kit includes the following:
We may be reached at info@ccperformance.com or 313.369.2447 for any questions or concerns.
- Garrett T-15 turbo charger
- Cast iron exhaust manifold with IF 101 houseing
- Exhaust piping and heat shield
- Air filter and MAF housing
- ADJUSTABLE EFI Controller w/ MAP sensor for EASY tuning
- Charge piping w/blow off valve
- Intercooler with fan
- Oil pick up and return
- 30 amp relay for fan
- Uses stock muffler
- Detailed instructions
